Old 08-23-2006, 11:15 PM   #1
Solver
Solver's Avatar
proportioning valve reset
Lost pressure on rear line and it drained the front reservoir on master .
Brake light came on so I know the prop valve is working. How can I reset the proportioning valve to allow fluid to back lines again?
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 08-23-2006, 11:35 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: proportioning valve reset
Maybe this will help...
http://www.classicperform.com/TechBo...t.htm#testprop
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 08-24-2006, 12:38 AM   #3
71/454
Turbo Guy
71/454's Avatar
First try fixing the leak and tightening all the bleed valves add the fluid and pump the ever lovin beeswax outa the pedal and let it sit for a while probably a couple hours and then vacum bleed from the furthest point from the master working towards it. Had the same problem on a 90 with rabs my mechanic friend suggested this and it worked. hope it helps
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles.
1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit!
Things I've broken so far:
12 bolt diff
saginaw 4 spd many, many pieces
Aluminum case Super t-10 4 spd
71/454 is offline   Reply With Quote
Old 08-24-2006, 07:23 AM   #4
jacobs
jacobs's Avatar
If the prop. valve is working properly, and everything else is ok, they will automatically reset by pressing on the brake pedal. Now Ford's are a different story.
jacobs is offline   Reply With Quote
Old 08-24-2006, 08:12 AM   #5
molnar55
Junior Member
molnar55's Avatar
remove the brake pressure switch. look in the hole and you will see a small rod. there should be a groove in the rod. most likely it has moved either front to back. take a small pick and move the rod to the center position and reinstall the switch.
1967 C-10 6ft Fleet
1972 C-10 6ft Fleet
1955 Belair 2dr post
1984 C-10 6ft Fleet
1999 Chevy Tahoe
Click Here For Our Online Store:
http://estore.websitepros.com/1269809/StoreFront.bok
Home Page:
http://www.bumpandgrindgarage.com
molnar55 is offline   Reply With Quote
