08-24-2006, 08:44 AM | #1 |
Tranny Question????
MY 86 K10 HAS A FRESH REBUILT 700R4 TRANNY AND THE TRANNY DOESN'T WANT TO "KICKDOWN". THE TRANNY SHIFTS THROUGH THE GEARS FINE AT NORMAL ACCELERATION BUT WON'T KICKDOWN. I HAVE ADJUSTED THE "TV" CABLE AT FULL THROTTLE FOR SHIFTING. WHAT COULD IT BE?
'87 BUICK REGAL 350 '82 CHEVY C10 SHORTBED '06 DODGE RAM MEGA CAB 2500 4X4 CUMMINS '87 MONTE CARLO SS AEROCOUPE |
08-24-2006, 01:00 PM | #2 |
Re: Tranny Question????
No Thoughts Huh????
08-24-2006, 05:32 PM | #3 |
Parts and more parts
Try to tighten up on the TV cable a couple notches and see if the shift works then. It oculd be the TV is not getting enough alignment. Another thing, did you replace your valve inside with a heavy duty one? If so, then it may start shifting better with some miles on it. AND for the last thing---My Son's truck was acting the same and we replaced the governor with a Corvette setup and the shift is now sharp and chrisp. His acted up for a better part of a year, then with the change of the governor, instant change.
08-25-2006, 08:30 AM | #4 |
Yes It Has The Corvette Servo In It, I Think My Problem Might Be The Bracket For The Tv Cable. It Is An Aftermarket P.o.s. And I Don't Think It Is Letting The Cable Have Enough Throw.
08-25-2006, 02:24 PM | #5 |
I did some measuring, for length, and then made my own with some metal and a little welding. It can be done with bolts and pop rivets, if needed. I have done a couple and it isn't that hard.
