Old 04-22-2002, 08:54 PM   #1
Jesse 67 c-10
Jesse 67 c-10's Avatar
Post Help!
I'm trying to finish up my 327, five speed swap, and disk brake swap but I'm having a few problems. All I have left is the driveshaft, hydraulic clutch hose some brake line to bend. My 5 speed is out of a 90 chev 1/2t, a getrag (nvg3500) The output shaft is 32 spline. A new slip yoke is $250 so I'm going to turn down a 32 spline yoke that I found in a yard, the outside is too big to fit in the tranny. My problem is this, I can't find anywhere what the outside dimension is sposed to be. If I go too small it won't ride on the bushing in the end of the tranny. There are none of these yokes in Saskatchewan to measure and I havn't been able to find a mechanic who can help me! Does anyone have one, know specs or know if it's the same as a th400 yoke(also 32 spline)? I want to drive my truck! Help!
Jesse
Near Saskatoon, Saskatchewan, Canada. 67 c-10, Long fleet, Newly swapped front disks, 5 lug rear end, 327 v-8 with Vortech heads, edlbrock performer rpm air gap manifold, 1406 carb and comp XE 256 cam. Backed by a getrag 5 speed and 1 piece driveshaft. Finnally running, almost driving! www.geocities.com/chevy67jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 04-22-2002, 09:06 PM   #2
69 longhorn
Post
I had a 5 spd yolk slipped into a 400T. the only difference that I could see, was the lenght of the spline(the 400T had an O ring,so the yolk was bored for that). good luck.....69 longhorn
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-22-2002, 09:12 PM   #3
Jesse 67 c-10
Post
That sounds promising, where is the O-ring on a turbo 400 yoke? I would guess on the out side nearer to the u-joint? no idea really, any other info? Thanks!
Jesse
Old 04-22-2002, 09:19 PM   #4
69 longhorn
Post
I didnt say that right,the O ring is on the shaft,& the 1st 1-1 1/2 " of the yolk is bored for it.......69
Old 04-22-2002, 09:48 PM   #5
Jesse 67 c-10
Post
I understand, so unless the 5 speed yoke is a bit smaller it should be the same outside diameter as a th400. Has anyone put a th400 yoke in a 5 speed now? Thanks!
Jesse
