08-24-2006, 10:44 PM | #1 |
Slugish
advice on cutting rear frame snubbers
I have lowered my 84 C10 to the point where I am looking to get more travel out of the rear. I would like to try cutting the rear "snubber mounts" out before I C-notch the frame. Do you guys have any advice on what the best way is to do this or helpful tools? Any help would be appreciated. Thanks.
-Will This is the only picture I have of my truck on my computer. |
08-24-2006, 11:30 PM | #2 |
In Progress
Re: advice on cutting rear frame snubbers
i took the rubber bump stop out. you can pull it out easily
1993 Chevrolet K2500 454 4L80E 1974 GMC 1/2t 2wd Stepside 305 auto *sold* 1985 Ford Mustang GT 5.0 5spd |
08-25-2006, 01:10 AM | #3 |
Until Seventy Times Seven
1974gmc - I think he wants to remove the actual mounts themselves.
slugish - You could try an air chisel to remove the 4 rivets. But, you may have better luck with a angle grinder or a drill in removing the head of the rivets. I prefer a 1/2" electric drill with quality drill bits. But, you may have trouble getting a drill in there. If you use a drill, start with a smaller bit, then step up to the larger size. Cutting oil also helps considerably. Once you remove the heads, you should be able to punch out the rivets. BTW, the truck looks good. What size do you have on it?
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
08-25-2006, 06:55 AM | #4 |
yeller
If you are going to c-notch the frame...why not just leave them in until then? When you notch the frame they will be on the piece you are cutting out anyhow.
Truck looks nice by the way.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
08-25-2006, 09:25 AM | #5 |
Insert Witty Text Here
I took his question to mean that he would like to try it before resorting to cutting the frame. As in, see if removing the snubber will allow him to avoid doing a c notch.
I am interested in this same subject. I only have about 1.5 inches of suspension travel right now in the back. Slonaker |
08-25-2006, 09:27 AM | #6 |
Slugish
Thanks for responses . Trying to stay away from c notching. Once bracket is removed should have approx. 3 more inches of spring travel. Have tried a sawsall & grinder , finally gave up. A***** to get off. Shouldnt this be enough spring travel ,without having to c notch ?? . will try drill, never used a air chisel.
08-25-2006, 03:53 PM | #7 |
Stepsides RULE
You went with drop leafs huh? If I go with shackles/hangers would I still maintain some of my travel in the back?
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
08-25-2006, 04:22 PM | #8 | |
If I hit a really big bump going fast, it bottoms with a THUD! I'm not used to slowing down for stuff, and don't want to start. I know I can get a little more travel by trimming the rubber snubber, but I would like to get as much travel as possible without cutting the frame. I really don't want to do that. I'm still happy with it, and I think you would be, too. |
08-25-2006, 05:20 PM | #9 |
Slugish
Ifirst did shackles & hangers which gets you down approx. 4 inches. Still had enough spring travel then . Wasnt satisfied with look, had rear leafs dearked 1.5" . snubbers about 1 " from axle. cut 1/2 of snubber off. then had springs dearked 1 more inch. You live & learn, should have done a flip kit & be done with it . Oh well , hind sight is wonderful. If Ican ever get those snubber brackets off I think I WILL BE OK. wILL LET YOU KNOW WHAT HAPPENED.
08-25-2006, 10:31 PM | #10 |
Slugish, would you recommend doing a flip if you could do it again? I have a shackle/hanger kit, but still might to an axle flip, help me out??
08-25-2006, 11:49 PM | #11 |
Stepsides RULE
Slone you are the man. I'm going with the 2/4 drop largely because how well your truck came out.
I think I'm going with shackles / hangers with drop shocks... a little cheaper IIRC and like you said, it might not bottum as bad. I couldn't imagine it bottuming out... going to work and back I take the Pineville Expressway which is concrete and its anything but smooth... and at 60 MPH you're bouncing ALOT. But I won't be dropping until I at least start the body work.. especially since at least one of the bed mounts is broken... you can pick up the box at one corner
08-26-2006, 01:08 AM | #12 | |
For most driving, a minimum of 3 inches between the axle tube and the frame rail should work. Unless, of course, you have a load on the truck. Once you remove the snubber mount, you could always install a button (low profile) snubber to protect you if you ever bottom out. Good luck.
08-26-2006, 01:24 AM | #13 | |
Should try to obtain at least 3" clearance after lowering the rear without having to notch the frame.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... Last edited by boxrodz; 08-26-2006 at 04:34 AM. |
08-27-2006, 01:38 AM | #14 | |
I'm using stock shocks with shock extenders with no problems. Right now it only bottoms if I hit a big dip going fast. A good example is an intersection where they set it us so the road dips on either side of the road you cross. It hardly ever bottoms out, though. |
08-28-2006, 09:50 AM | #15 |
Slugish
If you use shackles & hangers ,the bed frame rails will have to be notched a little , which isnt that much of a deal. Should have ample spring travel with that set up. If you want to go lower than 4 inches (to 6 inches or so) flip kit should be your best bet, but this is where you run into bottoming out problems
