08-25-2006, 12:53 AM | #1 |
Rim leak .
What can i use to seal my 15 x 3 Super Tricks , they have brand new Moroso tires , and the silicone seal looked to be in good condition , but they don't want to hold air , one is worse than the other , is there a product you can recomend ? I'm getting sick of having to air them up every couple of days .
Thanks ............................................. 409
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
08-25-2006, 01:20 AM | #2 |
Too Dumb To Know Better
Re: Rim leak .
gasket sealer.
08-25-2006, 06:12 AM | #3 |
Re: Rim leak .
you need to find where its leaking first// soapy water will show if the leak is valve stem, tire bead, tire, or in the rim itself// valve stem have it replaced, tire bead dismount clean and prep both surfaces and remount, tire repair/replace, rim replace because it might be unsafe and fail in the future at speed
08-25-2006, 08:06 AM | #4 |
Re: Rim leak .
I had a Weld Outback that was leaking.Dismounted tire and saw no flaw in the weld @ center with my naked eye.I cleaned w/brakeleen and spread a tri-polimer caulk (Geocel) thoroughly over the entire area all the way around the wheel.It held air until one day months later,it went completely flat in a short time,wouldn`t hold air when airing it back up(my truck has a compressor).Dismounted again,saw a crack 2/3 around entire center.The wheel was coming apart.If the wheel itself is the culprit,have it repaired by a wheel restorer,send back if under warranty,or toss it.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 08-25-2006 at 08:08 AM. |
