Old 08-25-2006, 03:25 PM   #1
shelby987
shelby987's Avatar
Gear Vendors Overdrive install
I have searched the forum, and didn't come across anything, was thinking maybe I missed it, is there a write-up on a gear vendors OD install, in particular I am interested in what the process entails to go onto the back of an NP205 t-case. I have seen a couple of pictures, is it just an adaptor, no cross member? Does the adaptor pitch the unit toward the rear end, or is it level with the transmission/t-case centerline?
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 08-25-2006, 05:12 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Gear Vendors Overdrive install
Not sure about a write-up, but we do have a member w/ one in his rig
As for who it is and what his user id is all I can say is someone please
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-25-2006, 05:36 PM   #3
TP from Cntl PA
TP from Cntl PA's Avatar
I was wondering the same thing............I've been debating about putting one on my K-20 as well............I was also thinking about a Ranger OD from Advanced Adapters, but that would require a tranny/t-case move 6" or so to the rear of the truck, which would require driveshaft work(No biggie) but I don't think the SM465 shifter would clear the bench seat, and the t-case shifter would be iffy.
I would just like more splits for the gears I currently.
I seen a Dana splitter on ebay acouple years ago for $400 which is what the Ranger is patterned after............I am STILL kicking myself for not clicking the "Buy it now" button.........I imagine most people wouldn't want them since it is another stick to run, but having been raised around old Macks with Du and Tri-plex's it doesn't bother me
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 08-29-2006, 05:56 PM   #4
TP from Cntl PA
ttt...........I'd like to hear more about one of these behind a NP205.
Old 08-29-2006, 08:31 PM   #5
kwmech
You remove the rear yoke and seal housing, they give you a clamp that holds the rear bearing in place. Then the adaptor bolts on. The unit follows the centerline of the shaft. The wiring harness (hooked up correctly) will not allow O.D. engagement in 4wd. Just make sure that you shim the small sleeve correctly. All the instructions are in the package. Not all that hard.
kwmech is online now   Reply With Quote
Old 08-29-2006, 08:42 PM   #6
TP from Cntl PA
My question is about the driveshaft angle..........Looks like a GV would change it to the point it would require other changes? I've seen the units on extended cab pickups and crews, but the extra length doesn't effect them like it would say on my smaller wheel base K-20.
Old 08-29-2006, 08:46 PM   #7
kwmech
The long wheel base helps alot, I guess it would depend on the amount of lift you are running. There is a 1350 CV flange available that can be used instead of the standard u-joint.
Old 08-30-2006, 12:00 AM   #8
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Here's a write up on a Doug Nash divorced unit [I believe its US Gear now] , not exactly what you inquired about but might give you some ideas. http://67-72chevytrucks.com/vboard/s...ighlight=drive
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 08-30-2006, 07:03 AM   #9
gator2511
gator2511's Avatar
I have the unit on my K 10 shortbed and I've had no problems with it. I went to a TH400 and had to move everything back about 4 inches. Just get the rear drive shaft shortened. No Problem. Of course my truck has no lift on it. You can see some pics of it on my link.
gator2511 is offline   Reply With Quote
Old 08-30-2006, 07:19 AM   #10
rage'nrat638
rage'nrat638's Avatar
click on picture
[IMG][/IMG]
rage'nrat638 is offline   Reply With Quote
Old 08-31-2006, 10:48 AM   #11
Lemield
Lemield's Avatar
I've got one on my CST 2wd behind a TH350. I don't know if your questions are 4wd specific but I'd be glad to answer any questions if I can. I LOVE my GV unit!! It works great. I installed it myself and the instructions in the kit were great.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 08-31-2006, 01:31 PM   #12
Schralper
Schralper's Avatar
http://www.gearvendors.com/
The only issue w/ a 4x4 is driveshaft angle.
I'm planning on installing a GV OD behind the T400 in my 2wd p/u.
Schralper is offline   Reply With Quote
Old 08-31-2006, 06:37 PM   #13
JRB
JRB's Avatar
Gator2511,
I was wondering what the benefit of the GV verses a 700R4 or a 200R4? It seem like a lot of money for an overdrive.
JRB
JRB is offline   Reply With Quote
Old 08-31-2006, 08:25 PM   #14
TP from Cntl PA
Originally Posted by JRB View Post
Gator2511,
JRB
A GV or any other type of auxiliary(Doug Nash, Ranger from AA, etc) isn't just an OD, you can split your regular gears with it........and it multiplys your speeds.
That is more of the reason I want such a unit, need the extra gears for towing.
Old 08-31-2006, 08:58 PM   #15
JRB
JRB's Avatar
Thanks for the info. I take it that it must help your Gas Milage?
JRB
Old 08-31-2006, 09:01 PM   #16
TP from Cntl PA
JRB
I don't think the splits would much...........The OD in the truck original high gear does. The splits ease the shock loading on the drivetrain while towing IMO, and like I said, sure makes it easier running in the mountains and hills with the extra speeds.
Old 08-31-2006, 09:28 PM   #17
nate68
you get a lot quicker acceleration with the extra gears
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 09-01-2006, 12:24 AM   #18
Schralper
Schralper's Avatar
Gator2511,
JRB
Price out one rebuild and it's a bargain!!
No way you're gonna trash an TH400/OD in the same time as a 200/700.
I've been thru enuff hassles w/ T700's that there's NO WAY I'll go that route again. Maybe 4L80 seems like more hassle, same $$.
Splinting is cool cuz you can keep it in the powerband all the time if you're willing to click and shift.
Old 09-01-2006, 12:40 AM   #19
skokie
skokie's Avatar
How much does one of these units go for?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 09-01-2006, 06:45 AM   #20
gator2511
gator2511's Avatar
Hey JRB. Its a lot of money but with a th400 and the GV unit I feel like the strength is there to tow with confidence. Also I had a 700R4 in my Vette and really didn't like the 1st gear. Can't use it in 4wd though. RPM's on the highway came down about 1,000 at 70mph. You get to use your cheaper transmission and still have OD.
Old 09-01-2006, 03:16 PM   #21
dennislbrooks
dennislbrooks's Avatar
I ran a GV OD in my 86 toyota 4wd behind a 350 turbo and a NP205 --- newer transfer cases may have a switch that does not allow the overdrive if in 4wd ---- if you do not just hope you can lose traction on either ther front or rear if engaged while in 4wd. I traded my np205 GV adapter for one without the transfer case --about $600 for my 2wd 67 C10. I like the gear vendor but unless you run a lot of HP or heavy towing --- a 700R4 is less expensive. GV's are better than $2600 now plus you have the cost of a trans.
dennislbrooks is offline   Reply With Quote
Old 09-01-2006, 06:46 PM   #22
gator2511
gator2511's Avatar
Well, You are absolutely right. I tow a 6100 pound travel trailer to where my son and I hunt several times a year. My Wife and I also camp a little. The 700R4 wouldn't serve me very well under these requirements. I almost put a 700R4 in anyway but I just got nervous about how strong they are. I read (as we all have) about the problems associated with the 700r4. I mean you really have to set them up properly or they won't last. I'm not saying they are a bad tranny but a TH400 and a GV OD works for my requirements and its easy to install and will last. If the tranny goes out its cheaper to rebuild. Its expensive to start with but in the long run I think my set up will work best for me.
Old 09-01-2006, 08:50 PM   #23
nate68
2600 bucks into a 700r4 should make it bulletproof. i'm sure you can get a pretty stout one for around 2k (i think)
Old 09-01-2006, 09:08 PM   #24
TP from Cntl PA
Bulletproof Slush Box.............I didn't know their was such a thing?
I would want one for the fact that I'd rather pay a bit more for a GV for behind a SM465, than put a NV4500 in for ALMOST the same amount of money and only gain 1 gear(OD)...........And if I sell the truck, take the GV off, put the stock parts back on and the GV goes to the new toy with a proper adapter.
Old 09-01-2006, 11:50 PM   #25
Schralper
Schralper's Avatar
Once you add in the converter, the one I had built last yr for my 4x4 Burban came in close to that. This is the 3rd "built" 700R4 in the burban.
Yeah the truck weighs 3 tons but so what.
I still waould rather have a TH400/GV OD
