5 speed
i've got a 70 1500. its a 3 speed on the floor. are there any good 5 speed or 6 speed trannys out there that fit ?? i assume im going to have to get some sort of hydraulic clutch setup. or does anyone know if there are any out there that will use the mechanical linkage ??
Re: 5 speed
there are mechanical linkages tranny out there such as keisler kits and classic chevy 5 speed you are talking pretty big money.
some of us use a nv3500 tranny out of a late 90's truck, others use late model camaro trannys they have the hyd clutch. use the search and you should find much info on this.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
Re: 5 speed
When I get to that point on my project shortbed,I`m going with a Doug Nash unit.Check them out in a Summit catalog.I`m building mine to be new,mechanically.Not worried about the expense.
Active Member
![]() Join Date: Dec 2005
Re: 5 speed
Finally got my Keisler Tremec installed behind my 250" in my '67 this week. It fits in perfectly (if you are willing to cut your floor and bolt-in a high-hump tunnel). The throw between 1st and second is only 4" with the Hurst shifter that comes with the kit. It has a .64 5th gear for mileage and will handle 550 HP. Appears to be a sweet deal. I think the 3K is worth it. I plan to have the trans for a while. I've got pictures if anyone is interested.
Special K - Sorry we won't see you today at Mattc10's.
The older I get, the faster I was!! |
DON'T TREAD ON ME
![]() Join Date: May 2005
Re: 5 speed
Here is some info on the TKO 500.
http://www.5speedtransmissions.com/6...truck_5sp.html
Old Yeller |
