Old 08-26-2006, 01:00 AM   #1
lutherb69
? about Hummer wheels
I have a 68 C10 Burban 2wd 6 lug. Just got (5) H3 Hummer wheels to put on it. What else do I need to get to make them work. I have seen a few members use the H2 on there 4x4's. Any help would be grate thank you for your time.
lutherb69 is offline   Reply With Quote
Old 08-26-2006, 08:17 AM   #2
396 SS
396 SS's Avatar
Re: ? about Hummer wheels
are you sure the H3 wheels will fit , I thought they were the same as a trailblazer and they have a different 6 lug bolt pattern. The H2 are 8 lug and will fit a 3/4 ton
396 SS is offline   Reply With Quote
Old 08-26-2006, 10:07 AM   #3
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
check your back spacings, like the h2 wheel they look liike they have 4-5" of bs.
what is the new lug pattern ?? 6 x 5.5/135 is the standard for the older stuff.
trkklr77 is offline   Reply With Quote
Old 08-26-2006, 06:58 PM   #4
lutherb69
Yes they are 6 x 5.5 (139.7 x 6 ) I'm not sure how to fine out back spacing. The offset is 25 if that's the same thing. The thing is the hub is 106mm on the rims but is like 90mm on the truck. Should I just try to sell them or can I get something to make them work?
Old 08-26-2006, 08:27 PM   #5
lutherb69
ttt
Old 08-27-2006, 08:22 AM   #6
I`ve seem plenty of wheels work that did not ride on the center hole.The back-spacing is the measurement from back of mounting suface on wheel center to inner bead/rim.
Old 08-27-2006, 09:57 AM   #7
msgross
msgross's Avatar
offset is the difference between the backspace and the center of the rim. It's either positive or negative. Backspace is your distance from the back of the rim to the back of the center lug area. Maybe 5 inches or so?
msgross is offline   Reply With Quote
Old 08-27-2006, 05:05 PM   #8
lutherb69
ok I found out I need to get centric ID 90mm OD 106mm and adapters of 1.5" to 2". Anyone know of a Co.?
Old 08-28-2006, 12:08 PM   #9
70rs/ss
70rs/ss's Avatar
I would unbolt a wheel from your truck and try the H3 wheel before I spent another dime on them. Like said above, the H3 is 6 on five, not 6 on 5.5 like our trucks. I just bought a set of Escalade wheels (18") and was looking at a set of wheels that where from the trailblazer/H3 platform and was told they would not fit. For wheel adaptors, go to ebay and search wheel spacers/adapters.
70rs/ss is offline   Reply With Quote
