08-26-2006, 08:47 AM | #1 |
11/2 or 15/8 primary tube?
i am doing the headers now, but need help on the primary tube size. 68 truck
i have stock 307 that i am planning on keeping for 1 to 2 more years. then i will put 400 with 906 vortec heads in. either way i want to keep the torque up. i have decided on full length ceramic coated hooker comps. exhaust pipes 21/2 non manderal bends, H pipe, exit rear of truck, 3 chamber type mufflers. now i have been wondering about that old/new thread in engines 307 strocker. so i need a compromise keeping in mind i may not go with the 400, but will for sure use a vortec head. any suggestions? |
08-26-2006, 10:55 AM | #2 |
Re: 11/2 or 15/8 primary tube?
I am not familiar with the heads you are using, however, I am building a 406 and plan on needing 1.75" headers. Since you may change your mind on the engine, I think it would be a mistake to buy the headers before you decide on the engine. A chicken before the egg kind of thing....
08-26-2006, 11:15 AM | #3 |
67-72 Addict!
I would go with the larger headers since you are planning some type of bigger engine in the near future.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
08-26-2006, 11:29 AM | #4 |
thanks never sure what i will do in future so i guess i will go with the 1 5/8 primary hooker comps. what about exhaust pipe size? 2 1/2 kink bend over kill?
08-26-2006, 10:32 PM | #5 |
Fabricate till you "puke"
1 5/8 " primarys are fine on a mild "street" 383 or 406, & 2 1/2" pipes are about right on for the big inch sb mills......on the 307, I would say 2" pipe tho.....2 1/4 MAX. There is no "free lunch" , if you want to build it once, build it after the 406 is planted..... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
