Old 08-26-2006, 04:08 PM   #1
71/454
Turbo Guy
71/454's Avatar
3 spd bellhousing dimensions
Does anyone have a 3 speed bellhousing loose that they can measure. Or does anyone know what size the hole is on the trans side and what size clutch that bellhousing will accept off by heart?
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles.
1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit!
Things I've broken so far:
12 bolt diff
saginaw 4 spd many, many pieces
Aluminum case Super t-10 4 spd
71/454 is offline   Reply With Quote
Old 08-26-2006, 04:09 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: 3 spd bellhousing dimensions
i got a 11 inch clutch in my i think 10 1/2 and11 works
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-26-2006, 05:02 PM   #3
gmc67swb
gmc67swb's Avatar
Not sure of the dimensions but I 2nd the 11" clutch. We have a CenterForce dual fricition in ours.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 08-26-2006, 10:10 PM   #4
crazy longhorn
Fabricate till you "puke"
67 & older....4 11/16 hole in the bell. 68 up gets a 5 1/8" hole to pilot the trans.....3spd or 4spd doent matter. L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
