heater valve
I've been trying to get my A/C blowing ice cold. One of the things that occurred to me is that my heater hoses are getting really hot. It appears to me that my heater valve isn't closing (getting vaccum). Shouldn't this valve close when I turn the temp lever on the controls to "cold", or should the valve close when I turn the a/c lever to "inside"?
"Green Monster" (Red Sox fan) 1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: heater valve
Yes.
The feed hose will stay warm but the return going from the heater core back to the rad or water pump should be cooler if the shut-off valve is working.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
Re: heater valve
Also make sure the heater hoses aren't hooked up backwards. The 5/8 line from the intake goes into the heater valve and then into the lower heater core nipple and it returns from the upper heater core line through the 3/4 hose into either the water pump or radiator. If its backwards, hot water will sit in the heater core and although it won't flow, heat rises and you will have hot water in the heater core all the time.
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
Re: heater valve
I've got the hoses on correctly.
For the meantime, I think I'm going to wire tie my valve closed, and see if that helps. And the "closed" position occurs when the valve is getting vaccum correct?
Re: heater valve
I believe so,yes.
To make sure though disconnect the vacume line at the shut off valve with the controlls set on A/C and see if there is vacume.
Re: heater valve
That's my problem, I'm not getting vaccum at the hose right now. Something's not connected correctly in my dash, and until I can get that fixed I need to rig the valve shut. Thanks.
