Old 08-26-2006, 07:16 PM   #1
CMars45000
CMars45000's Avatar
Best way to shrink metal when there is no acces to the rear of the panel?
I managed to use my new stud welder to pul some dents in the tailgate of my 71 but in one are in particular where the dent was BAD, the metal has streched a bit and is oil-canning in the lower left region of the tailgate. What is the best was to shrink this metal in order or prevent it fron oil canning?
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 08-26-2006, 09:03 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: Best way to shink metal when there is no acces to the rear of the panel?
You may want to do a search here. They have lots of good info on sheetmetal working. www.metalmeet.com
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-26-2006, 09:08 PM   #3
72CSTC5
72CSTC5's Avatar
Use your stud welder and weld studs in that area and quickly wipe the metal with a wet rag and that will shrink the area tight. You do not have to worry about pulling the dent there, you are just using the nail for heat. Good luck.
72CSTC5 is offline   Reply With Quote
Old 08-26-2006, 09:28 PM   #4
bagged74
its just $$$$$
bagged74's Avatar
you can probably get a shrinking tip for you stud welder. just heat it and immediately cool it with water or compressed air.
bagged74 is offline   Reply With Quote
