battery hold down/nhra tech
will the stock battery hold down pass tech at the drag strip for the street legal drags? do i need to modify or change it, or will it pass just fine?
Jim (or anyone else who races at the Redding Drag Strip), what are you doing for a battery hold down? how strict on tech are they? i've checked the nhra rules and this is my only concern
68 short step, 406/700r4, 9" w/discs. |
Re: battery hold down/nhra tech
I would move the battery to the rear frame rail under the bed! Most tracks don't tech that hard but the oe hold down is weak!!!!!!!!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
i might do that eventually but for now it's staying where it is. i have the little optima adapter (like that really makes much of a difference) on there.
i dont want to drive an hour to the track and not pass tech.
its all about the +6 inches
call the track with your expected ET and MPH and tell them you have a stock hold down... unless you have a fast truck, you'll probably be OK.
i'm not all that concerned about it. I wanted to know if anyone had any issues a their track.
what was GM thinking? i think this part of the design process was done on friday or a monday (with a case of the mondays)
![]() Join Date: Nov 2005
Mine passes tech , and it's the stock set up . No problems . I have , however seen how much damage a battery can do if it gets loose , not pretty.
Later ........................................ 409 ![]()
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
IUf your stock hold down is in good shape, it is better off than many hold downs. (assumijng the correct size battery is installed)
Slide one side of the battery base under a lip that won't move, then clamp down the other side of the base with a 3/8 inch bolt. When my first truck got totalled, (front passenger side direct hit) the battery stayed in the tray. She was going an estimated 60 MPH when she hit me. |
Wrap a ratchet strap around it and the tray, to the rad. support. My Blazer passed that way once.
