![]() Join Date: Aug 2005
'67 Inside Door Handles
What makes the '67 inside door handle remote controls so special? Can a '68-'71 be made to work? I know the shaft is longer on the '72.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
Re: '67 Inside Door Handles
" remote controls "??? The only remote control I have is the kid... HEY BOY! OPEN THE DOOR! But I think he's special....
If you can't drive it park it! If you can't park it milk it! Last edited by Geezer; 08-26-2006 at 10:01 PM. |
the shape of them is a little different. More like a 66 style. Most of the 67's I buy may have one original and one 68 up but rarely are both still there.
Bob - The 67 remote has a shorter nub (out board of the clip) than the 68-71remotes.
Hope this helps - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
Thanks. That's what I thought. Since '67 inside door handles are different from '68-'71 as well, you ought to be able to use both the '68 style handle and remote together, right?
Right. You could use 67 handles if you shortened the nub.
Don't know if you have 67 window handles to match or even if you have the 67 door handles? Good luck. Keep it looking "67" original if you can - Bob
davidh called it: I have a '68 remote on the left side with some aftermarket handle, and a '67 remote and handle on the right!
