Old 08-26-2006, 10:21 PM   #1
68jimmy
68jimmy's Avatar
Tips on breaking in new disc brakes??
Just as the title says.... Any tips appreciated!
Thanks!
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 08-26-2006, 10:39 PM   #2
msgross
msgross's Avatar
Re: Tips on breaking in new disc brakes??
Always put that "anti-squeek" stuff on the back of the pads before installing. You can also take some emory cloth to scuff up the disc prior to installing....
msgross is offline   Reply With Quote
Old 08-26-2006, 11:03 PM   #3
crazy longhorn
Fabricate till you "puke"
Go out and do 6 or 8 medium/hard stops from say 45 mph, allowing time to cool......then just drive her like you would. L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-26-2006, 11:08 PM   #4
neonlarry
neonlarry's Avatar
Check out this article:
http://www.stoptech.com/tech_info/wp_bedinstock.shtml
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 08-26-2006, 11:22 PM   #5
centsless
sufficiently talented fool
centsless's Avatar
Everything that I have read recently recommends that you brake normally and avoid panic stops or excessive heating of new rotors/pads for 500 miles. The new materials used work better and last longer with a break in period. The older non-metallic pads did better with a few hard stops to seat the pads.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
