08-27-2006, 08:40 AM | #1 |
JB1 JB3 JB5 JD3 JD5 What is all this
I am putting a crossmember out of a 84 c-10 that had a 6.2 desiel into my 69 c-10 and I am wondering whick of these above codes would match up to the brakes
the brakes look kind of beefy and I can wait to see the difference in the discs vs the drums. |
08-27-2006, 12:17 PM | #2 |
Re: JB1 JB3 JB5 JD3 JD5 What is all this
nobody knows about the brake codes
come on! |
08-27-2006, 12:33 PM | #3 |
Look here . Click the correct suffix and you should find what you are after. Frank
http://www.73-87.com/chevy_ids/rpomenu2.htm
Born and proudly residing in a Red State ! |
07-09-2016, 02:43 PM | #4 |
I have the same problem.
How do you figure out which booster to use? I am putting a 1984 cross member from a C10 into my 69. had no intention to change the rear drums yet. Any thoughts about JB3 vs JB5? JB3 BRAKE, POWER, DISC/DRUM, 4600 LBS JB5 BRAKE, POWER, DISC/DRUM, 6400 LBS
1968 GMC truck 910 Trim (Canadian) 127" WB 3 on the Three Trans (Saginaw SM330) 250 ci L6 Engine HEI ignition (early 80s L6) |
07-11-2016, 11:23 AM | #5 |
Moderator
JB3 has a single diaphragm booster
JB5 has a dual diaphragm booster and slightly larger (wider or larger dia) brake shoes. http://67-72chevytrucks.com/vboard/s...d.php?t=203698
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
07-12-2016, 09:08 AM | #6 | |
I'd just opt for the JB5 system. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
07-12-2016, 11:38 AM | #7 | |
I'm just glad to be here!
BTW JB3 is the 1" thick rotors JB5 is the 1.25" thick rotors
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
07-12-2016, 04:09 PM | #8 |
And let me add that pads are the same, but calipers and spindles are different. Been there, done that.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
07-12-2016, 05:08 PM | #9 |
I had a mix of JB3 and JB5 parts on my truck for some time. Had the thicker rotors (axle was from a 3/4 pickup) with the smaller pads and the JB3 calipers. It all fit fine. I also had the large 13" brake drums on the back.
Then a year later I updated to the JB5 calipers and larger pads and new JB5 rotors as the rotors that came with the axles were warped and shook when stopping. I did keep the old JB3 Master Cylinder and it seems to work fine, not sure why the JB5 one is needed there, maybe someone can chime in on that. I know the booster is larger and the MC is a little bigger too. |
07-12-2016, 09:10 PM | #10 |
Here are a couple representative brake system release charts (from 1974, and from 1987), which break down the systems by part number.
http://67-72chevytrucks.com/vboard/s...d.php?t=510519 These are the charts the design engineers developed, and used as a reference when releasing the part numbers into the production and service database. All part number information flows from these. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 07-13-2016 at 07:08 AM. |
07-13-2016, 07:14 AM | #11 | |
Moderator
07-13-2016, 10:41 AM | #12 |
My truck has 1JJ5 heavy duty brakes RPO sticker in the glove box. It's a 85 c10 1/2 ton would that be JD5 brakes?
07-13-2016, 11:57 AM | #13 | |
Double check that code from the sticker in the glove box, it should only be 3 characters, not 4. My bet it is faded/damaged but actually is JD5...
07-13-2016, 12:25 PM | #14 | ||
Mine has a "9" in front of every code. Quote:
Posting the '87 chart as a reference since I had it handy ('85 would be the same except for the C/K/R/V model designation). JD3/JD5 is hydraboost; JB3/JB5 is vacuum. You then need to know your GVW in order to determine which system you have ("3" vs "5"). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 07-13-2016 at 12:46 PM. |
07-13-2016, 12:58 PM | #15 |
07-13-2016, 12:59 PM | #16 |
Here is the glove box info. maybe you guys can help me figure it out.
07-13-2016, 03:37 PM | #17 | |
From the powertrain chart below: 1985 C10703 w LE9 & MX1 & GU2 = 6100 lb GVW From the brake system chart above: 6100 lb GVW= vacuum system = JB5 brakes. Answer - JB5. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 07-13-2016 at 03:44 PM. |
07-13-2016, 03:38 PM | #18 |
The option list and powertrain chart attached above are from the generic info packet located in the GM Heritage Center archive.
1985 Truck: https://www.gmheritagecenter.com/doc...olet-Truck.pdf K
07-13-2016, 04:21 PM | #19 |
Thanks guys...........
07-14-2016, 07:39 AM | #20 | |
My guys may have installed your front fenders and pickup box. K
07-14-2016, 08:48 AM | #21 |
learned something new. I have never seen the 4 digit RPO codes on the spids.
Nice to know that there is dummy character so that they are still the "normal" codes...
07-14-2016, 09:59 AM | #22 |
It was strange for me as well. I have always seen 3 digit codes. That's why I came to you guys.
