Old 08-27-2006, 01:45 PM   #1
crawdad
crawdad's Avatar
Cruise Control
Well, I went and bought another one. An 86 long bed this time. I plan on using it to do a little towing and working around the house, but that was just my excuse for getting it I'm trying to get the bugs worked out of it right now, and I was wondering if any of you could give me some advice on how to trouble shoot the cruise control. It looks like everything is there, but thats about all I know about cruise. What are some of the things I need to check to find out why it isn't working? Thanks.
2012 Silverado LT 1500, 5.3, 6 speed auto
'86 SWB C-10 Silverado
crawdad is offline   Reply With Quote
Old 08-27-2006, 07:09 PM   #2
Phuloi68
Re: Cruise Control
Button control on turn signal bad, broken wire in column? cruise control unit at bottom of column bad? Fuse?
Just a couple of ideas.
Phuloi68
Indy survivor
Norwood survivor
Big Sandy survivor
for those who fight for it...
F R E E D O M
has a price the protected
will never know.
Phuloi68 is offline   Reply With Quote
Old 08-27-2006, 11:53 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Cruise Control
The wiring breaks a lot on the switch from what people tell me. It can be replaced in a couple of hours. The whole stalk is only about $45 or so in the HELP! section at auto parts stores if you don't need a chrome one. I replaced mine when the stalk broke off.
While you have it apart, it is a good idea to tighten up the bolts on the tilt mechanism if you have it. I didn't because it felt pretty tight, and it was flopping all over the place a couple of months later. I got to pull the whole thing apart again. Oops. I always seem to learn things the hard way...
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 08-28-2006, 10:18 AM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Cruise Control
If you go to the GM dealer and open up a shop manual for that year of truck, there is a whole troubleshooting section in there. This has you go to different plugs in the sytem and read out voltages. That will tell you what is faulty. Have the dealer copy the pages for you or look to buy a used book from them, they may have more than one in the stroage area.
piecesparts is offline   Reply With Quote
Old 08-28-2006, 12:34 PM   #5
crawdad
crawdad's Avatar
Re: Cruise Control
Ok, thanks fellas. I'll start checking things out. I'm an absolute dumbazz when it comes to things electrical, but I'll see what I can do.
Old 10-14-2006, 09:46 PM   #6
pcmcobra
pcmcobra's Avatar
Re: Cruise Control
My cruise went out today....
I have the dash apart, what should I be looking for/at?
I see the black wire on the turn signal going down the column, then below I see a single black wire plugging into a plug with about 4 or 5 wires coming out and going uptowards the firewall. What am I looking for.
What a PITA.
thx for any help. Gonna keep the dash apart tomorrow and see what I can do.
pics:
help, please....
pcmcobra is offline   Reply With Quote
Old 10-15-2006, 08:07 AM   #7
piecesparts
Re: Cruise Control
The cruise control has a couple of module boxes for it. The first being under the dash, mounted on the firewall by the gas pedal. The other is the actual module on the engine, that has the carb connected to it. The cruise stalk has four wires coming from it and it goes to this box on the firewall. Then the connections feed to the engine unit. The engine module has the vacuum connections for the diaphragm control and it is basically nothing more than a positioning unit, receiving data from the inside controls. The speed feed signal comes from a wire plugged into the back of the speedometer in the instrument panel.
The troubleshooting manuals from GM, start at the plug (from the cruise control stalk on the column) at the inside firewall box. The readings are taken with a ohm meter and is looking for continuity. The wires are fragile and break easily. Odds are that the problem will center there. The readings will lead you to what is working and what is not in different modes. It is not a simple explanation, but once you have the book infront of you, the steps are designed to lead even a FORD mechanic through the troubleshooting. I recommend a trip to a dealer and make copies of their pages, or buy a book somewhere. I purchase one for every vehicle that I buy and then keep them.
Old 10-15-2006, 11:32 AM   #8
72freak
Rottenwood Garage Member
72freak's Avatar
Re: Cruise Control
I will sound stupid...but when mine went out...there was a small round booster looking thing on the firewall beside the brake booster in the engine compartment. It has a linkage attached to it that runs down to the throttle body area. The linkage had broken off the booster looking thing . I re-atached it with a zip tie and that was my problem. Its workes ever since
72freak is offline   Reply With Quote
Old 10-15-2006, 02:03 PM   #9
pcmcobra
pcmcobra's Avatar
Re: Cruise Control
I found some info on alldata
I tested the plug from the switch on the turn signal lever to the bottom of the column with an ohm meter per instructions, all was well.
I'm putting my dash back together today. Not going to worry too much about it right now. I might fiddle with it if I get bored.
thx for the info.
