Old 08-27-2006, 03:11 PM   #1
jasonrmorrow
Lets see some Plumbing Pics...
I've got my airbags on schraeders at the moment, tank/compressor/valves will arrive next week...
I know there is more than one way to plumb the system...I want to see some pics. I'm planning on running the tank behind the cab on the frame rail...i like the "cleanliness" of mounting both the fill and dump valves right at the tank, then just having lines to run.
I gotta make my list of fittings, its easier to picture with the **** all in front of me...but pictures are the next best thing.
Soooo pics...lets see em.
1964 - LWB 350 TPI Fuel Injection
On airbags
jasonrmorrow is offline   Reply With Quote
Old 08-27-2006, 04:15 PM   #2
robsm88
robsm88's Avatar
Re: Lets see some Plumbing Pics...
Hope to see some pics too. I am just a few steps behind you in my progress.
robsm88 is offline   Reply With Quote
Old 08-27-2006, 08:58 PM   #3
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
[IMG]http://*****************/how_to/wire-diagrams/8valve.gif[/IMG]
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 08-27-2006, 09:19 PM   #4
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
The closer you can have your valves to the bags the better. I'm running my front valves under the core support, and the rears are just inside my rear bumper on a bed cross-sill. 2 3-gal tanks, 1 on each side of frame rail just behind cab, and I've got 2 Viair 380c comps mounted under the cab on driver framerail so I can hear if something is malfunctioning. I put an extra strip of rubber on each side of the feet for extra sound-deadening so they're not overbearing right under me.
For your fittings, just be prepared to have to go back and get more, or just buy plenty extra up front with the intention of returning some. I ended up doing both.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 08-27-2006, 11:10 PM   #5
jimmydean
jimmydean's Avatar
Why would you want the valves near the bag? I was looking at the Air Lift install guide and they run from the tank to both valves, then the line all the way to the bags. There is a T to the gauges, but that's it.
jimmydean is offline   Reply With Quote
Old 08-28-2006, 12:25 AM   #6
PBFAB.COM
PBFAB.COM's Avatar
The closer the valves are to the bag the quicker the bag will fill (less volume of line to fill up). It truly doesn't make that much of a difference. I prefer mounting the valves in an area that is easily accessible. That way WHEN it's time to do some maintenance or repair or replacement of a valve it's easier.
PBFAB.COM is offline   Reply With Quote
Old 08-28-2006, 01:06 AM   #7
jimmydean
jimmydean's Avatar
PB, that makes a lot of sense now tha I can visualize it, thanks for the explanation. I liked the way they mounted the dump valves on the frame rail in Project Old School. They mounted them on the outside of the frame rail under the driver side cab for front, and passenger side for rear with the fill valves mouted on the tank. I look at this truck a lot because it is very close to where my truck is headed for the build.
<edit> Here is a funny quote from the article:
"When it comes to plumbing techniques: if there are four people in the room, then there will be four "right ways" to set up your system. My opinion: function over form. Easy access and the least amount of chance of the lines kinking are what I look for in a good install."
Old 08-28-2006, 01:18 PM   #8
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
I would reccomend "manifolding" the valves together using brass fittings rather than airline between the valves. I had like that the first time I bagged it and when I back halfed it I manifolded them and I think it turned out alot better.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 08-28-2006, 10:03 PM   #9
67Fleet
67Fleet's Avatar
That's how mine are and it looks super clean that way.
-Bret
Old 08-28-2006, 10:08 PM   #10
jasonrmorrow
Do you guys use "t's" with tapped holes for your gauge pressure...or do you use a cross with a bushing...
the t's are a custom made piece arent they, a cross with either a nipple to go from 3/8ths npt to 1/8" tube would work...is that nipple avail ?? If not then i have to do a bushing to an 1/8" PTC nipple.
Soooooooo many fittings
i have 26 counted so far, just get the bags air...not including gauges, or attatching the compressor or the water trap...luckily a friend of a friend owns a hose headquarters/abilty hose type place.
On airbags
Old 08-28-2006, 11:00 PM   #11
jimmydean
jimmydean's Avatar
What I am looking at is stupid simple. Nipple from tank to fill valve. Street T from fill valve to dump valve. Elbow with gauge fitting from fill valve to bag.
So from tank to bag, I have:
3 nipples
1 street T
1 elbow with gauge fitting
1 elbow to bag
1/2" line to bag
1/8" line to gauge
It might not be the fastest setup, but I am going for simple. Each line is independant, there are as few junctions as possible, and I use hard line and fittings where they count.
I hope to have everything here by next weekend and start the tear down and build up then.
Old 08-29-2006, 05:57 PM   #12
camaro__thunder
Pretty much all you will need to know.. http://www.bagginit.com/
My Project 69 SWB
Old 08-29-2006, 06:19 PM   #13
jasonrmorrow
3 nipples
1 street T
1 elbow to bag
1/2" line to bag
1/8" line to gauge
Well thats the exact setup i had planned, 24 pieces for 4 bags, then you have to plumb the rest of the tank...
and those elbows with gauge fittings, are they available or custom made.
On airbags
Old 08-29-2006, 10:02 PM   #14
jimmydean
jimmydean's Avatar
Originally Posted by jasonrmorrow View Post
Well thats the exact setup i had planned, 26 pieces for 4 bags, then you have to plumb the rest of the tank...
What i was looking at were the T that Suicide Doors carries that has a gauge fitting on it, then plug one end. I will wait to see what I find local before I get too crazy. As for the rest of the tank, all I need to add is a water trap and drain plug. My tank, compressor. and bags will be here tomorrow and I will have a better idea what I need then.
I got a nearly full kit off ebay that someone bought and never put together. So it has a couple fittings and I don't know how many ports are on the tank (I think it has 8). But from the compressor to the tank, you can just run the hose that's on the compressor to a water trap, then a nipple from the trap to the tank. So maybe another $.60 for the nipple and your set.
I will get all my crap together in a week or two and hope to have it all done in a couple days after that.
[IMG]http://www.*****************/images/products/mid_12BrassTeewith1890DegFitting.jpg[/IMG]
Old 08-29-2006, 11:12 PM   #15
jasonrmorrow
I knew suicide doors had em, and by looking closer at that pic and seeing the "flat" under the gauge fitting it looks like its manufactured that way, rather than being a "custom made" tee by suicide doors or the supplier.
The Tee with a fitting would be the cleanest and least # of connections.
My crap is all stuck at the border, unfortunately i bought through a small company...so i have to call everyday to see if its there...i trust the guy, even though it was a 100% deposit on the parts...hahaha I said "So you want me to pay for them up front".
I'll make some calls tomorrow to see if that piece is commonly available.
On airbags
Old 08-30-2006, 03:18 AM   #16
onehot69stepside
onehot69stepside's Avatar
[IMG]http://www.*****************/images/products/mid_12BrassTeewith1890DegFitting.jpg[/IMG][/QUOTE]
use this tee to manifold your valves. That way you have straight shot lines. No "splices" anywhere. And then just use longer guage lines to run all the way to the valve assembly/manifold.
:mp:
onehot69stepside is offline   Reply With Quote
Old 02-28-2007, 11:30 PM   #17
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
when you say manifold them together, what do you mean?
i assume you mean something like, 1 line from the tank to a T, then on each side of the T, put a valve. is this correct?
wouldn't fill time be a little slower since you have one line going to two bags?
IvelDesigns is offline   Reply With Quote
Old 03-01-2007, 12:00 AM   #18
BK
BK Built
BK's Avatar
where does everyone run their lines out of their front bags? i have mine run through holes in the rear of the crossmember above the bag in the coil spring pocket that i drilled and wollowed out. i was always concerned about it rubbing through. does anyone know where to get 1/2" grommets? pics help.
BK is offline   Reply With Quote
Old 03-01-2007, 12:25 AM   #19
jimmydean
jimmydean's Avatar
You should be able to get grommets of any size at NAPA or Ace Hardware. I have also made my own using a quality rubber cement when needed.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
Old 03-01-2007, 12:48 AM   #20
thekid54
I found that most gromets didn't work with the super thick metal found on these front crossmembers. The grove between the two outer lips wasn't big enough. I used 3/8" rubber fuel line hose and slit it down the middle lengthwise and wrapped it around the plastic airline, making a sleeve for it. There were 2 holes (one on each side) under my motor mounts that I used to run the airline through, just had to enlarge them a bit.
This may be a stupid question, but how does the 1/8" gauge line attach to, say a viar gauge? What gives it an air-tight seal. Am I missing something or am I just retarded?
thekid54 is offline   Reply With Quote
Old 03-01-2007, 12:51 AM   #21
BK
BK Built
BK's Avatar
well, with my guages, it was just a quick release in the rear of the guage, similar to the larger ones for big lines. not sure exactly how it works, but it seems to.
Old 03-01-2007, 01:36 AM   #22
Rollie396
someday it will be done!
Rollie396's Avatar
I used these bulkhead fittings for plumbing the lines through the crossmember.Had to clearance the engine mounts a bit but it works well.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 03-01-2007, 03:50 PM   #23
short step
suicide doors has free shipping on fittings ,also check http://www.fittingsdepot.com/index.html
bob
short step is offline   Reply With Quote
