Old 08-27-2006, 03:42 PM   #1
tom71
what happened to flint mi
tom71's Avatar
has any one ever seen a 90 over sbc piston?
who makes these things? i saw seven of them this weekend . and i thought 60 to 80 over was pushin it on a small block?
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 08-27-2006, 03:49 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: has any one ever seen a 90 over sbc piston?
I've seen an 80 overr 350 running on the street with no problems...but never heard of more.
Old 08-27-2006, 03:55 PM   #3
tom71
tom71's Avatar
this 90 over had no problems at all the guy said he hauled over 7000 pounds from san diego to idaho no problems ther valves got all gummed up , ended up sticking and that was the end of that piston i guess that s why i saw 7 of them and not 8
97 fiance mobile
Old 08-27-2006, 04:37 PM   #4
cdowns
cdowns's Avatar
call up a manufacturer like aires they'll make up any type you could imagine i had an edsel engine once and jahns made me a set of 125over pistons
Old 08-27-2006, 08:46 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Usually only .060 over is recommended but that is due to casting shift.The mold used to cast the block shifts some when it is poured.The cylinder walls may be thinner on one side and not have enough material to bore more.The block can be sonic checked for cyl wall thickness.Some of the aftermarket blocks come with thicker cyl walls and can be bored much more.Another consideration is that the cyl wall needs to be thicker on the wall in direction of crank rotation.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-27-2006, 11:56 PM   #6
cst70rocket
I pulled a set of .090 over 350 pistons from an old chevy school bus a few years back. I've still got one, if ya need it!!
cst70rocket is offline   Reply With Quote
Old 08-28-2006, 11:15 AM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
Back in the good ol days you could buy 125's for almost any engine. They were rebuilt with more tlc back then.
My 350 had 80 overs installed by a p.o. You can almost buy another block for the cost of the pistons.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
