Old 08-27-2006, 10:23 PM   #1
BigMike
BigMike's Avatar
Silly request - Woodgrain bezel overlay
Hey guys...Some of you may know that I am wanting to smooth out the rough finish of my bezel, the part that is black. I have debated sanding it, filing it with high build primer or a self leveling epoxy. I think Longhorn Man has suggested getting the woodgrail overlay and painting it. I think instead of ruining a woodgrail overlay, I could just use it as a pattern. I would go to Home Depot and get some thin lexan and use the woodgrain overlay as a pattern, then paint the lexan the color of my truck. I can use an epoxy to adhere it to the bezel (thought of double sided 3M red tape, but it would be too thick). I would make sure it fit perfectly before assembling it as not to ruin my bezel if it is not a perfect fit.
SO, anyone have an old woodgrain bezel OR a template that they had made that I could get from them or know where I can get one inexpensively?
Thanks,
Mike
BigMike is offline   Reply With Quote
Old 08-28-2006, 10:46 AM   #2
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Silly request - Woodgrain bezel overlay
Instead of buying one for a pattern, make your own pattern. You put tissue paper over the bezel and use a lead pencil to make a rubbing of it. Cut out the tissue and test the fit. Adjust as necessary and wah law, a pattern. I've done this for making gaskets.
HG
hgs_notes is offline   Reply With Quote
Old 08-28-2006, 01:04 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Mike, I have used duct tape in the past. Overlap the strips for strength. Use an x-acto to trim the edge and holes. When you are done, it will peel off and stay together!. I have done it before a few times and it's easy to do. Good luck!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-28-2006, 01:28 PM   #4
BigMike
BigMike's Avatar
Thanks guys for the ideas. I have a bunch of different sized transfer tape that I use with my vinyl plotter. I used a single sheet of 11" tape and it worked pretty well to cover it. I then traced it out and wil pick up some lexan tonight and give it a try.
Mike
Old 08-28-2006, 03:35 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I'd think the lexan would be more expensive, and too thick. Let us know how it works out.
Old 08-28-2006, 07:20 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
BTW- If you do use Lexan make sure that's what you buy. There is a big difference between Lexan and Plexi-Glas
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-28-2006, 07:44 PM   #7
BigMike
BigMike's Avatar
10/4! I work with Lexan all the time and you are right, there is a big difference between the two. My Home Depot (or at least the one I consider mine as I have paid enough to them to fund their new expansion) has several different thickness choices. I am going to go with the thinnest piece I can get. I am also debating on painting the inside so the lexan would act as the clear coat (just like the RC Car Bodies I paint).
I'll let you guys know how I make out.
Mike
Old 09-02-2006, 10:55 PM   #8
chevybill
chevybill's Avatar
well, big.mike any progress?
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 09-03-2006, 12:44 AM   #9
BigMike
BigMike's Avatar
I have not had a chance to work on it here lately. I will try to get something going here soon on it though and post my progress.
Mike
Old 09-03-2006, 08:41 AM   #10
I`m going to a crafts store and getting Decoupage.It`s resin that flows to level.Like on a bar where they have coins or pictures encapsuled under the finish.It will flow to the bezels and dry smooth and flat.You could paint first or on top of it.I`m going to paint over it.
