![]() Join Date: Jun 2006
I have been thinking about using a shielded side exhaust kind of like was on
some of the earlier corvettes. It would come out at the rear of the front wheel and end near the back of the cab. Was wondering if ya'll had any opinions on the nosie level, etc. This is on a 68 that I'm just starting on. Will probably install a mild 350. Patriot exhaust products offer these in different lenghts. Thanks, bob |
67-72 parts finder
Re: Thinking about insatalling 'side exhaust'
probably not legal on a daily driver depending on where you live i know in missouri on a daily driver they are not legal exhuast has to exit 18 inches behind the cab. my dad had some on his 69 swb they were sweet
every one i've ever seen on a truck looks dumb IMO but they're good for a laugh
Post Whore
If NC is as lax on vehicle requirments as KY then they are probably legal, you are planning to run it past the cab and to exit right in front of the rear wheels aren't you, I think it would look sweet and sound sweet, but I like my exhaust pretty loud.
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons ![]() |
If you like glasspacks, nuff said. I had a pair on my 59 Apache when I was in HS, it was cool untill I got a new perspective on cool. They look good on vettes, but they will burn the crap out of you legs (I learned on a 68 BBC vette!) legal is probably going to require them to vent as close to the front of the rear tires as possible, anywhere near the cab and you'll be deaf in no time.
its all about the +6 inches
The federal requirements only reqire it to be past the rearmost opening door, and exited out from under the vehicle. the early 97 F-150 had a tail pipe in a similar location from the factory. Since your truck is not required to have cats, therefore you can place pipes anywhere you want (illegal to relocate a cat... considered tampering) it would be safe to assume they would be legal... however, if your state is anal about stuff like that, double check. But I'll pretty much say with 99% certinty, you''ll be ok.
Personally, i like side pipes. However, you have to do the whole truck up in a classic hot rod style (IMO) in order for them to look right. I had planned to go that route with my old SWB. |
for a truck, visible side pipes would be too long to look right. i run the exhaust in front of the rear wheels but they're not visible except for the tailpipe, and also i have cutouts below the door to run without mufflers.
you'd have to run a 3 inch pipe to make it look good in my opinion and are you planning on running a muffler? some companies like patriot exhaust or something makes a kit that is a side pipe hidden muffler, but they're short, for a car. it would be unique. |
Chevy truck addict
The LuvShack Garage
No side pipes on "GQ" but I do have it exiting in front of the rear
wheels, it's only rowdy when someone is parked next to me ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
all the side pipes I've seen had mufflers built in. Jeggs has an S pipe kit that makes them easy to hook up.
-Chris
![]() Join Date: Sep 2002
Hey Bob, Im here in Jacksonville NC and I stopped in at the local Advance Auto to pick up some things and ran into an old man with a 68 short bed step side with those pipes. He had it dropped, 50 series tires, and a beige, off white two tone paint job. It looked killer. He had the 5 inch pipes running down the side and turned out before the rear wheels. I loved it, even though I was not a huge fan of them before that day!
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt. BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481 2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's 2017 Chevy Suburban (Wifes Car) - Fully Loaded & Stock "Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem." Ronald Reagan, President of the United States; 1985 |
350+dual flows= fun :)
hey bob!....still need that 68 camaro wiper motor?!
#13 |
#14 |
Post Whore
Hey does anyone have pics of side pipes on one of our trucks? This sounds like it might look pretty cool on the 71, long way from that step but it never hurts to dream!
#15 |
Must be a different Bob, I haven't inquired about a wiper motor.
bob |
#16 |
The heat shield on the 50" Patriot side exhaust is aprx. 36" long. I thought
about modifiying the rocker so that it has a more concave shape and tucking it close to the cab. Maybe insetting the lower rear cab sheet metal so the outlet would tuck closer to it. Sort of like the cab was made for it. I'm thinking the heat shield would not look right if it was longer than the cab. I guess the lower bedsides could be modified in the same way if a longer heat shield was used. Thanks! bob |
#17 |
if its '71 or ealier you don't have to have any inspection of any kind in NC. so it will be legal. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
