Old 08-28-2006, 10:51 PM   #1
wcav11
Rear panhard bar w/ airbags?
I bought an adjustable rear panhard bar(trackbar) for my 71'. I'm currently baggin it. Where do you adjust it at? When its dropped parked or at driving position? Because when it's set at driving position and then dropped down the axle shifts way over and isn't centered in my c-notch. Am I just supposed to find a happy medium or what? Any tips let me know.
wcav11 is offline   Reply With Quote
Old 08-28-2006, 11:18 PM   #2
powell72
powell72's Avatar
Re: Rear panhard bar w/ airbags?
It's supposed to be centered at drive height. Do you mean it isn't centered left to right in the notch or front to back? Left to right is normal. You might have tire rubbing issues if you are running a fairly wide rear so rail carefully so you don't burn paint if you go with some meat in the back.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 08-29-2006, 10:19 AM   #3
Tony@AirRideTech
Junior Member
You need to adjust it to center at ride height. You also need to get it parallel with the gound at ride height.
Tony@AirRideTech is offline   Reply With Quote
Old 08-29-2006, 06:42 PM   #4
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
OK, lets take a step back here. You say you have an "adjustable panhard", but are you meaning the one that is adjustable but still mounts in the stock locations, or do you mean the one that mounts at the stock frame location on the driver side and goes all the way to a mounting point on the passenger side trailing arm? If you have the first one I'm describing, and are bagged, then I would ditch that one and get the one that goes all the way across to the trailing arm. There WILL be more side-to-side movement with the first one I'm describing due to its shorter length.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 08-29-2006, 08:54 PM   #5
wcav11
It's an adjustable in the stock location, but I am going to be running some meat 335/25/22's. So this thing jumps over about an 1.5in when dropped from the ride height. So do I just gotta play with it till it clears everything?
Old 08-29-2006, 08:55 PM   #6
wcav11
Where do I get one that goes to the trailing arm?
Old 08-29-2006, 09:54 PM   #7
jimmydean
jimmydean's Avatar
CPP makes one called the Deluxe Trac Bar (part #6572DTBK), and ECE makes one called the Super Trac Bar (part #902-6572TBK). Both are designed for trucks lowered more than 4". The adjustable ones are for stock to 4" drops (not bags).
jimmydean is offline   Reply With Quote
Old 08-29-2006, 10:22 PM   #8
67Fleet
67Fleet's Avatar
Yeah, if you're bagged you're gonna need the longer "deluxe trac bar".
-Bret
Old 08-30-2006, 05:59 PM   #9
wcav11
Anyone wanna buy a brand new adjustable panhard bar?
Old 08-30-2006, 07:15 PM   #10
ortegamotor
ortegamotor's Avatar
nice thread, i didn't know that either.thanks for the info.i am bagging my Blazer and i would run into the same issue.Thanks again, Tony
ortegamotor is offline   Reply With Quote
Old 08-30-2006, 07:27 PM   #11
SCOTI
SCOTI's Avatar
While this statement is 'true', there is more than one way. I have the shorter adjustable panhard bar on my 68 w/bags & blocks. Since I don't run it throughout the entire suspension range, it works fine in its limited use.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-30-2006, 09:35 PM   #12
67Fleet
67Fleet's Avatar
hehe, I've also got one w/ about 2 months of use and less than 300 miles......It's sitting in my garage collecting dust.
-Bret
