RIP Mr Ron
![]() Join Date: Dec 2005
Can this be done.
I have an old 1967 C-30 truck that needs everything. It is complete but wore out. I have 3 mid seventies 1 tons with good front ends under them. Can I do like the C-10 guys and swap a late model front cross member with a power steering box under it. Has anyone done it and what kind of trouble did you have. I know it would be a lot easier to just build the later models but I just can't take this old girl apart. Any help is appreciated. Thanks.
Ron (Mr Round Tuit) ![]() Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
Fabricate till you "puke"
Re: Can this be done.
It should be pretty much a bolt in, but you will have to "oblong" a couple bolt holes. The crossmembers are said to be the same , from 10-30 series. Just be sure to use ALL the steering linkage from the later truck. best of luck,
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Junior Member
I have not done this swap on the one tons but.... the one tons and 3/4 tons actually share most of the suspension components in the front end. That would leave be to believe that it will be the same to swap as a 1/2 ton.
RIP Mr Ron
Thanks guys. I haven't messed with any 1 tons or 4wd stuff in a long time. Let the destruction begin.
Ron (Mr Round Tuit) ![]() Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket Last edited by Ron 586; 08-29-2006 at 04:15 PM. |
Ron - If your frame is a 67 1T you will probably have to dimple it to fit a PS box. Heat and a BFH will do the job. I have yet to see a 67 frame (1/2, 3/4 or 1) that had a dimple to fit the PS box.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
RIP Mr Ron
Thanks Bob, now that I'm ready to try to save it I have 2 people trying to buy it. Strange.
