Old 08-29-2006, 04:58 PM   #1
HD2000
HD2000's Avatar
Drilling doors for wire loom
Hello,
Wondering if anyone has any advice on drilling holes in the doors for running the wiring harnesses for power windows and locks?
I have the kit from A1 electric and plan to start the install shortly (bought the kit years ago but the truck project has been on hold while I was playing with bikes).
I have the same "wiring boots" that ChevyDude has installed in his thread on the Brothers one piece glass install (didn't want to hijack his thread with my off topic question) and I notice that he has installed them quite low in the door (1" above the bottom hinge if memory serves). Is that the best placement or would it be easier if I ran them a little higher in the door? (I am not installing 1 piece glass)
Thanks all
HD2000 is offline   Reply With Quote
Old 08-29-2006, 05:02 PM   #2
John Fabris
TOTY 2006
John Fabris's Avatar
Re: Drilling doors for wire loom
I installed mine a little bit higher, but there is another metal wall in the door, if you have an empty door, look below the top hinge and you will see another pocket of sort, so I had to drill another hole from inside the door and put a rubber grommet there as well.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 08-29-2006, 05:32 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Anybody know where the Factory holes would have been? The CST was
offered w/ door jamb switches for the under dash lights, If I gotta drill I
wanna make sure it gets in the right place so it kinda looks like factory.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-29-2006, 07:00 PM   #4
john
member #16
john's Avatar
There is a raised boss on the jamb for the switches. They are for the dome light or under dash on a blazer. You cant miss them.
john is offline   Reply With Quote
Old 08-29-2006, 07:03 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Tyvm
Old 08-29-2006, 09:15 PM   #6
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
This is how I did it.
low'n slow is offline   Reply With Quote
Old 08-29-2006, 10:02 PM   #7
HD2000
HD2000's Avatar
Thanks all for the info. That last photo from low'n slow, with the door closed and fender off, helped me a lot with the perspective (side to side). Looks like I will go with the hole about the same height (just below the door pin switch) as it will make it a little easier for me to fish the wires into the cab (I drilled a hole up fairly high under the dash - above the e-brake).
Thanks again
Old 08-30-2006, 12:54 AM   #8
low'n slow
low'n slow's Avatar
These wire looms were from a Saturn.
Old 08-30-2006, 02:26 PM   #9
project1971
project1971's Avatar
Thats some good info and pics THANKS!
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
project1971 is offline   Reply With Quote
