Old 08-29-2006, 10:18 PM   #1
Boog
laying low
Boog's Avatar
power steering pump brackets
I need another steering pump for my 350 in the 69. So I need a pump and bracket for a later model engine since I am using the long water pump. My question is will the later model steering pump hoses match up with the flair and threads in the older steering sector? Sector is a 71. I would like to pickup a pump w/bracket and hoses used. I assume the pump assemblies off any 73 to 86 small block truck or cars would be the same? Is there a better deal out there? Thanks.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-29-2006, 11:29 PM   #2
Blue85
Oilfield Trash
Blue85's Avatar
Re: power steering pump brackets
all you have to do is unscrew the fitting on the back of the pump and swap it to the newer pump,takes a good pull to loosen it though
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 08-30-2006, 09:03 AM   #3
Boog
laying low
Boog's Avatar
My concern is over the hose end fittings. I heard somewhere along the way GM changed the fittings. Either from flair to oring or from standard thread to metric? I don't remember.
Boog
primer is finer
Old 08-31-2006, 10:24 PM   #4
purple gas
There seems to be a few differnt fittings. I tried a few differnt hoses that looked like they'd work, but didn't. I'm running a power steering bracket from a Van. It sits a bit lower than the one's made for trucks, but otherwise works good.
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Old 08-31-2006, 10:45 PM   #5
corn
Like blue85 said above. Take the fitting out of your old pump & screw it into the later style pump. You can have later long w/p style pump & early short w/p style hoses.
corn is offline   Reply With Quote
