08-10-2002, 11:33 PM | #1 |
Is the altenator bracket mounting bolt a special bolt (350V8)?
With the stock factory setup on a 307/350 V8's, the altenator main mounting hole is 1/2" diameter and the bolt is 3/8" that screws into the head.
Is there a 3/8" bolt with a 1/2" shoulder that you are suppose to use? A collor that you slap on a 3/8" bolt? None? I don't get it. A 1/2" hole in the bracket for a 3/8" bolt into the head. What do others have installed for this?? Thanks, -Roger
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... |
08-10-2002, 11:35 PM | #2 |
its all about the +6 inches
All mine were 9/16 bolts.
08-10-2002, 11:44 PM | #3 |
You just jogged my memory.
The old original stock engine had at least a 1/2" hole egged out that the previous owner botched and I re-tapped it for the altenator bracket. I just recently pulled that stock engine out and put in a GM crate 350 plain-jane engine and that is the one that has the 3/8" bolt for the altenator in the head. Ugh. Thanks. That answers it. -Roger
