Old 08-30-2006, 01:27 PM   #1
Orange
Licensed to Thrill!
Orange's Avatar
How do you/can you remove the kick panel cowl vents?
I need to get them out if possible (or just the passenger side at least) to see if I can put a drain down through there for my under dash a/c and to make that go a little smoother. It would also be a good time to replace my seals on them.
Thanks in advance.
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 08-30-2006, 02:02 PM   #2
BubbaGreen
Re: How do you/can you remove the kick panel cowl vents?
take the bracket handle loose. Open the vent as far as possible and at the bottom there should be a spring loaded pin (pivot point) which you need to push up on to clear the hole and tip out the vent door. If its rusted, spray with some wd-40.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 09-02-2006, 12:41 PM   #3
Orange
Licensed to Thrill!
Orange's Avatar
That's what I thought...and what I have been trying...
Hmm...
Thanks, gonna go try again.
DLB
