Old 08-30-2006, 05:51 PM   #1
motocrosschump
One Person Bed Removal
Well I decided to move the tank to the rear. So hooked a 6 ft chain to the crossmembers under the bed (making a V). Then I hooked a Tie Down strap to the chain and routed it through the fender well. on the other end I hooked it to an Cherry Picker. The Picker I pushed the legs on both sides of the tire to keep it from moving.
Then I jack the side of the bed up as high as I could without hitting anything.
Then got on the other side of the bed and lifted by hand and backed the off the truck to the side. Then I jacked it up as HIGH as it will go. and tilted the bed on its side.
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 08-30-2006, 07:46 PM   #2
MisterMan
MisterMan's Avatar
Re: One Person Bed Removal
your a machene man!!! it took 2 ppl for us..... damn heavy.
MisterMan is offline   Reply With Quote
Old 08-31-2006, 08:52 AM   #3
motocrosschump
I am not a little guy by no means. Well maybe by NFL lineman means.
Old 08-31-2006, 09:24 AM   #4
incoma
incoma's Avatar
You can also install eye bolts where the bed bolts to the frame, and lift it that way. I moved my hoist in from the rear of the truck, that way I could pull the bed completely off and set it on the ground. I'm always scared the cylinder will fail when I'm under whatever it is you're hoisting.
"Green Monster" (Red Sox fan)
1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension
incoma is offline   Reply With Quote
Old 08-31-2006, 09:27 AM   #5
cdowns
cdowns's Avatar
with a little bit of thought and the right tools one man can do alot
Old 08-31-2006, 09:27 AM   #6
motocrosschump
hmmmm, sounds even better.
Old 08-31-2006, 09:46 AM   #7
byrd
Union Electrician
byrd's Avatar
incoma, great idea!!! will have to use that one!!
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
