Chassis Help
Hello, I just purchased a (1957 Cab / 1959 Fleetside Bed) Truck. Truck runs great and looks Awesome it is however on a 72 Chassis. I like the fact that rear are coils vs leafs, frontend is all rebuilt, already has pwr steering/brakes. Biggest drawback is that fnt wheels are not centered in wheel well. They sit about 3" towards the rear when looked at from the side. Also they stick out about 1/4". Obviously this 72frame/bed,cab is not the best set up. So here is my question around the frntend, "Can I fix this problem?" I want wheels in and forward, maybe with a Mustang II or some other IFS system up front? Only thing I really want to achieve is to drop truck (bags). I've been searching for the specs on a 1972 chevy truck chassis but haven't had much luck. Any info will be much appreciated, Thxs.
Louie [email]ltorres1@cox.net |
Hollister Road Co.
Re: Chassis Help
I think the only way to get the wheels to fit and centered is an MII. the track width on the donor truck is to wide. To fix the wheel center problem you need to either move the cross member forward or the cab and fenders backward. neither one is an easy task. I have that same problem on my 58. I have a 75 cross member in it on a 58 frame. But I'm at the stage where its not hard to move the cab backward. You can get a bolt in or weld in MII from fatman fab.
And welcome to the forum. Last edited by dwcsr; 08-30-2006 at 08:17 PM. |
Re: Chassis Help
Thanks for the info, much appreciated.... This forum is great!
Louie
Hollister Road Co.
Re: Chassis Help
Another place to look for that MII install is www.webrodder.com I believe that have a tech write up on it.
Re: Chassis Help
68CRUSR, I have been looking into putting my 57 body on a 67-72 chassis also. The wheelbase of a 57 SB is 114" and the wheelbase of the 67-72 SB chassis is 115" so the wheels should almost line up. If your talking about a longbed, that is another story. The 57 LB is 123 1/4 " and the 67-72 LB is 127" so this would account for the wheels moving to the rear.
Re: Chassis Help
Welcome 68CRUZR!
1959 GMC project |
Re: Chassis Help
Thanks ron n ca, I'm assuming that is the reason why my front wheels sit towards the rear of the wheel well. I found a 59 chassis that I am picking up on Wed, now my question is in regards to the rear end. Most aricles regarding these trucks have a Ford 9" rear. I can't keep the stock rear simply because of the 6 lug. The gentlman at the yard told me that I cannot convert this rear end to 5 lug. What other options do I have other than the Ford 9"? I have some really brand new Boyd Coddington wheels that I plan to use for my 59. They are Magnetos 18 X 8 and 20 X 10. Thanks again.
Re: Chassis Help
New to the Ford 9" rear end. I'm trying to find out what if any modifications I would have to make to this rearend to install on my 59 truck (stock frame) I already have 20 X 10 wheels (5 lug). I had these wheels made for my 68 Chevy SB truck but now want them on my 59 instead. Any help would be greatly appreciated.
Re: Chassis Help
Oh yeah I looked at the 59 frame that I'm getting today and not sure if they all came like this but it has leafs up front. Obviously I need to swap this out, I am wondering what would be my best choice, Mustang II? maybe?
Re: Chassis Help
I used an S-10 Blazer 7.5 10 bolt and changed carrier to a Z-28 posi. The reason I went with the S-10 Blazer rear is one, the S-10 rears are narrow so I could fit my 20x10’s inside the fenders and two, the newer S-10 blazers had rear disc brakes. If you’re planning on going over 400 hp. then you might want to go with a 12 bolt or the Ford 9 inch, although something about putting anything Ford on a Chevy just don't set well with me!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 Last edited by CAL 58 GMC; 09-02-2006 at 01:55 AM. |
Re: Chassis Help
Cal 58 GMC, thanks for the info this really helps me out tremendously....What kind of set up do you have on your frnt? Your project is coming along just fine. Your a great source (postings/pictures) when is comes to ideas and info. thxs
Re: Chassis Help
Cal 58, I just remembered reading your discription on your trucks frnt end couple of days ago. So if I may ask a different question? What other frnt end do you recommend? My wheels that I need to work around with are 18X8's. If I were to do a Camero frnt end which years do I look for? I'm new to that custom upgrade. thxs
#13 | |
Re: Chassis Help
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 Last edited by CAL 58 GMC; 09-03-2006 at 03:17 PM. |
#14 |
Re: Chassis Help
Once again, many thanks. Love your truck.
#15 |
Re: Chassis Help
Hey Louie,
I live in North Phoenix and have a 1959 GMC with a 1975 Camaro subframe and rearend. I will be moving the whole project out to Chandler the beginning of next month. You are free to come take a look at my set up some time. I can take some pics if you like? Here is link to a million pics of the truck. PM me if you want to hook up some time and take a peek or talk trucks. http://www.imagestation.com/album/pi...?id=2118173837
1959 GMC project |
#16 |
Re: Chassis Help
Jebb1978, I was actually looking at some of the pictures that you have of all your progress and it looks great. I love the stance, especially when you pulled it out to the street. I'm assuming you installed the Camero frnt clip in your self, correct? I will definitly be getting with you to check out your work and talk ideas with you. So that's beginning of Nov correct?
#17 |
Re: Chassis Help
Cal 58 GMC, could not find in your post in regards to your leaf's, are these stock? Also, did you need to modify any brackets of anything else to make the S-10 diff work with your leafs?
thxs
#18 | |
Re: Chassis Help
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 Last edited by CAL 58 GMC; 09-07-2006 at 12:57 AM. |
#19 |
Re: Chassis Help
Cool, thanks for all the info. Hey what do you think of a 4 link rear?
#20 | |
Re: Chassis Help
Actually my Dad married the frames about 10 years ago. It was the second one he did. I am sure he would be happy to answer any questions you have. The day that the house is in my possesion is October first but I am sure it will take me a few weeks to get the truck over there. It will be one of the last things to go. I will keep you up to date with the move if you like.
1959 GMC project |
#21 |
Re: Chassis Help
Four links is bar far the best set up for the rear. They are fully adjustable and you get a great ride and easly bagged. Now the bad news, it also the most costly.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
#22 |
Re: Chassis Help
Thanks Jebb, looking forward to meeting you and checking out your truck.
Louie
#23 |
Re: Chassis Help
Cal 58 GMC,
As usual thanks for your input your opinion is greatly valued and appreciated.
#24 |
Re: Chassis Help
Your welcome Louie, anytime.
#25 |
Re: Chassis Help
Hey guys I had another question in regards to the 59 frame that I picked up. The 59 that came off this frame had leafs up front as well as the rear. Do you all know if the 57 frame is the same? When I look at the front-drive side to part it gets a little narrow, maybe for clearence? Not sure, I've decided to go with a Heidts or a TCI up front so that's why that question comes up. Thxs
