changing over gas pedal (help)
I want to swap over the accelerator pedal from rod type to cable . I have the cable and pedal . anyone done this any tips or pics ? it seems as though i cant use my existing holes so i am alittle stuck .
Re: changing over gas pedal (help)
search the faq section, i think putter done a write up on this.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Out of the carpool lane.
I happen to be doing this project myself right now!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
I love you guys i dont know how you find this stuff everytime i go to the faqs section i cant even come up with something close to what i am serching for .thanks a lot fellas
so why does everyone want the cable instead of the rod ?? i liked the rod setup in my 68 camaro ALOT. wouldnt mind changing mine over to rod myself.
I'm swapping over due to adding a 4bbl to my I-6 and it's sooooooooo much easier than trying to make the rod work and buying a bunch of expensive bellcranks and linkage and wasting time trying to hook it all up and....
![]() Join Date: Mar 2001
Main reason is safety....if an engine mount breaks and the engine rocks over....it pulls the throttle OPEN if its connected via a rod, very dangerous
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
I think the cable hooked to the right linkage looks alot cleaner. I am looking into all after market. "LOKAR" I have the lokar TH400 kickdown switch and bracket on my edelbrock carb right now. Soon I hope to instal lokar pedal's, and the cable for the gas pedal.
Gary
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
I got my pedal from an 80's chevy,just put it where it is comfortable and drill the three holes to mount it and another for the cable.If you are using the GM style cable youll need to make the hole square with a file so the cable can snap in there,cant speak for the lokar setup though
I put a cable set up in my truck, but I later switched back. To make the square hole I first drilled a round hole, then squared it buy using a Jig saw and cleaned it up with a file. was real easy
I got a bench seat baby, you don't have to sit over there. |
