SUPPOSED to get Viair 400...got 380 instead
Ok well kinda pissed off but help me out here...
I ordered a 400c,tank,valve,gauges from a local shop. Had to order from the US, parts got held at the border slightly late, not a huge deal. Told me to call him daily, i did for a full 7 days. **** gets here tells me to come get it, when i show up he has a 380C there for me in chrome, instead of the 400C plain steel. They were on backorder for who knows how long. Sooooooooo for my needs, 5 gallon tank, 4 path, 64 chevy 1/2 ton i wanted a compressor that would fill fast and shut off, 400c is the one i wanted, didn't see my self on the switches all the time, wanted to pull up to where i park, dump it, when ready to leave, fill it. 380c is 100% duty cycle 200 psi, but waaaay less CFM, fill time from 110-145 is almost a full minute longer, from 1:30 to 2:26. SHould i be pissed off, or put up with the longer fill time to possibly be able to hit the switches more, the fact is my 5 gallon tank will drop to 110 so fast that i cant really "play". Help me out...should i look locally for a 400c, or stick with my chrome 380C. Oh and he forgot to order my tank...can be had locally in two days or less.
1964 - LWB 350 TPI Fuel Injection On airbags |
belly dragger
Re: SUPPOSED to get Viair 400...got 380 instead
The 380 gonna run alot longer than a 400 series comp. Did he charge you the same? We normally have a fairly large stock of comps at the shop. If you want give me a call tomorrow 1 888 275 2588.
Rob |
#3 | |
And those Viair guages, the just have a threaded nipple on the back side, i assume i have to use compression fittings, but the ones i used on my bags had a sleeve you slid into the tubing and then the ferrule and then the sleeve nut. And the gauges are 1/8" line correct ??
You can use 1/8" or 1/4" for the gauges. I always have a hard time finding fittings for the 1/8" line locally. 1/4" compression fittings you can get at any home depot or hardware store. the threads on the guages are 1/8 male pipe thread
Hey man. I'm in Calgary too. I'm curious what shop you ordered from, if ya don't mind me asking?
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough! ![]() |
