Pulley Alignment Trouble
I removed the alternator, water pump pulley, crank pulley,and power steering pump from a 1971 chevy. I am putting it on my 327 engine. Te stuff was on a 350. I had to place one shim behind the water pump pulley and it looks to be lining up good with the alternator.. The trouble is the belt between the power steering pulley and crank pulley. The power steering pulley is closer to the block by about 1/4 inch. Any ideas ? I have tried numerous different crank pulleys but have the same trouble. Are there different off-set pwer steering pullleys out there?
67 is sold
Re: Pulley Alignment Trouble
Is the water pump shaft on the new motor a different length then the pump on the old motor?
![]() Join Date: Mar 2003
Are you sure that the harmonic balancer is pressed in all the way
Long pump stuff will not fit short pump stuff.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Not all pumps have the same pulley either
I have found 5 different offsets so far
