Oh,you can't buy that new
![]() Join Date: Apr 2000
Tach Info To Copy , Again
IF YOU DON'T SAVE THIS IT IS NOT MY FAULT. DAVE
all4trux@snip.net ,PLEASE READ ON FOR PROPER APPLICATION. This is one of those items that is commonly mis-advertised as 73-87 when in fact there are several differences in each unit The first thing to keep in mind is that GM did offer a Tach as an option after 1981 in light trucks,but they are rare as Hens teeth .I have found Canadian units that were supposedly from Mid 80's trucks/blazers but the speedo is in KmH .there are even guys on Ebay trying to advertise them as” 140 speedos” but don’t tell you that they are KMH not MPH. It would be easy to install a U.S. MPH speedo to it.There were 6 cyl. and 8 cyl. models available and a 6 cyl. one is going to read high in a V-8 application. 95% are probably V-8's. Try to know it works before you buy it. I have been TOLD that the 73-75 units are NOT serviceable[I verified this now] and if they are bad, and keep in mind that ANY service will probably set you back $125+. I see very few advertising that that “I saw this unit work” so you are on your own if you buy one not knowing it works. As a note * 30-40 % of the ones I buy are BAD either they don’t work at all or they read WAY off . The tachs are very easy to wire and check so there is no excuse in my book for a guy to say he never checked it ,yet try to get $100 or more for one . I also found out Most of the tach repair places do'nt carry parts for these year tachs. The Light trucks were only offered with a 5,000 RPM tach but I have seen 4,000 RPM ones also. probably big diesel. {when i say BIG ,I mean like a C-60/C-6000 series truck. The tach is easy to wire, but getting at least a short piece of the factory pigtail to the back of it is nice to have, But not a necessity. If you look close at the back of the tach it will tell you where the wires go. many people don't know that there was a 'filter', that looks like a condenser, installed in many years of the factory wiring for radio interference reasons.It was mounted on the firewall behind the distributor. this is not a necessity .Speaking of distributors it does not matter if you have and old point ignition or HEI the tach still works.I am not familiar with aftermarket ignitions ,but most have web sites with tech help that could answer your question. MOST Tach dashes WITH a VOLT gauge are the common ones and will work in 78-84 for sure as pretty much a "plug in and go" unit. It is possible to work on 1985 and 1986 models depending on what you have still have in the way of the factory computer [I.E.= if you have removed the factory feedback carb And ESC distributor, Etc. and DON'T need feedback then it will be fine]. As far as pickups go it will not work on an 87 and will not work on Blazers and Burbs from 1987 to 1991 because of feedback needed for the factory EFI computer(ECM). Again it can be made,and at least one will be made by me to sell. This is not a job for amateurs and you are going to need 2 units just to make one! ( THIS ONLY APPLIES TO THE MODELS REQUIRING A REAL ECM). The 1973 to 1975 models used an AMP gauge instead of the VOLT gauge and this can cause major wiring problems (meltdown) if installed in later trucks equipped for VOLT gauge or vice-versa. The 1976-77 used the volt gauge but had a mechanical oil pressure gauge and creates a two year only dilemma of sorts. If you find a 1976 or 77 unit with the VOLT gauge and the MECH. Oil pressure then it can be used in 78-up models by converting yours to mechanical, and actually better, oil pressure gauge. The only thing to keep in mind here is to get at least a little piece of the factory oil line and fitting that was on the back of the gauge. I say this because the factory gauge has a unique type of ferrule and fitting on the back of the gauge that is good to save and reuse. I have made aftermarket lines/fittings work but have also had them blow off the back and make one heck of a mess. The factory used a steel oil pressure line and I prefer that to plastic or you can buy 1/8" copper.now THE OTHER BIG PROBLEM WITH THE MODELS THAT HAVE THE mechanical oil pressure gauge instead of the of the Elect. One is that the whole cluster is wired differently because of that .I rewired one to work and it takes awhile and some ‘know how’ . I am by no means a ‘TECH’ but I do understand wiring. SO it is better to leave the 77-78 units alone also. Keep in mind that there were also several variations of needle colors and the type of lettering/numbers on the gauges. Mixing and matching gauges can create a weird looking unit. The big trucks ,like C-60's are easily identified by a tiny fuel gauge UNDER the tach and anything from a clock, air pressure gauge ,or vacuum gauge, to a blank CAN be where the small ,round ,lower left clock option goes in a pickup dash. Some big trucks only had 4,000 RPM tachs also[and you thought a 5,000 was too low]. LOL.. Big truck tach dashes can be made to work in a pickup ,but offer there own unique problems and the years of options mentioned above DO NOT directly apply to them. big things to get from all of this is , AMP or VOLT gauge could = FIRE. KNOW it works! or BIG $$ to fix, 6Cyl. or 8 Cyl., Elect. Or Mech. Oil pressure gauge?75% of sellers on Ebay Don't care about your concerns because i Email them all the time hoping they will correct their ad and they Don't. 25% are very grateful. ONLY 25%.!! YOUR WELCOME,DAVE -------------------------------------------------------------------------------- Back | Reply | Reply All | Forward | Delete | Move To DeletedDraftSent Back to Top all4trux@snip.net
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone 73 Pinto, stock, w/CragarSS's-eww ![]() 84,C10 SWB-Yella,stock 86 K10 SWB-Red, hopped up 305,4/S LOTS of Cummins trucks. |
| Bookmarks |
