Old 08-31-2006, 10:48 PM   #1
QKENUF4U
QKENUF4U's Avatar
Question all will fit ?????
just had a bud here thats into the 67-72 trucks also. hes telling me that all the fenders from 67-72 will fit my 71 without problems (other than one little hole for the rad support) this true ?
QKENUF4U is offline   Reply With Quote
Old 08-31-2006, 10:55 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: all will fit ?????
nope, not true
69 - 72 chevy ONLY. (assumin yours is a chevy.)
On the GMC side... yes, 67 - 72 all the same except the marker light missing in 67
Old 08-31-2006, 11:00 PM   #3
krue
Designated A-hole!
krue's Avatar
Tell your bud to join up!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-31-2006, 11:00 PM   #4
71swb4x4
71swb4x4's Avatar
The problem that Andy speaks of is the indentation for the grille on 69-72 Chevy fenders. The 67-68 Chevy and 67-72 GMC fenders do not have this indentation.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-31-2006, 11:48 PM   #5
QKENUF4U
QKENUF4U's Avatar
so could i use 67 GMC fenders on my 71 chevy or no (because of the grill shape ?) im doing away with the marker lights so it sure would be nice to not have to weld up those holes.
Old 09-01-2006, 12:32 AM   #6
Rod
you cant (well.... fit properly) 67 fenders on a 71 chev.
67-68 chev and GMC fenders are the same and interchange for those years .....still remember that there is no marker light hole on a 67 though.
now think 68 chev or gmc fenders fitting upward years only GMC's (69-72)
again 67 have no marker light.
but even a 67 chev fender will fit for any year 67-72 GMC..but without a marker.
its the 69-72 Chev fenders that are recessed in the front forward edge to accept the grill surround style of the 69-72 chevy grills..while the gmc fenders trim in the accessorized gmc's used fender eyebrow systems, which just mount by holes in the front fender edge.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 09-01-2006, 01:57 AM   #7
Chevyman680063
Chevyman680063's Avatar
The fenders from a 67-68 Chevy or 67-72 GMC will work but the problem you will have is that the 71 Chevy grill won't work with those fenders, at least not without modification.
67 Chevy & GMC
Name:  67 Chevy fender.jpg
68 Chevy & 68-72 GMC
Name:  68 Chevy fender.jpg
69-72 Chevy
Name:  69 Chevy fender.jpg
Notice that there is no ridge on the 67 Chevy/GMC fender and that there is a ridge on the front of the 69-72 Chevy fender that the other members mentioned.
Chevyman680063 is offline   Reply With Quote
Old 09-01-2006, 03:55 AM   #8
71/454
Turbo Guy
71/454's Avatar
Ok i'm a bit lost too i don't mean to hijack this thread but are 67 gmc and 67 chev fenders interchageable. Reason i ask is my friend wants to make a 67 gmc a 67 chev
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles.
1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit!
Things I've broken so far:
12 bolt diff
saginaw 4 spd many, many pieces
Aluminum case Super t-10 4 spd
71/454 is offline   Reply With Quote
Old 09-01-2006, 05:17 AM   #9
Longhorn Man
67 to 67, yes.
it's easier to look at it by part numbers;
67 chevy and GMC... one part number
68 chevy and 68 - 72 GMC ...one part number
69 - 72 chevy and NO gmc trucks ... one part number.
Old 09-01-2006, 06:32 AM   #10
The differences have been listed accurately.But,the answer is "all will fit."They will bolt to the cab and core support,no matter which fender you use.But,fitting a hood or grille is where the differences matter.Core supports are also different in Chevys:67/68 & 69/72(like fenders,hood,and grille)/in GMCs:The core support is the same.The difference in cores is in the headlight locations.
Old 09-01-2006, 02:32 PM   #11
71/454
Turbo Guy
71/454's Avatar
Thanks longhorn man
12 bolt diff
