Airbaggin
Hey guys, I was looking around for some air bags to put on my 70' Chevy C/20 pickup and only found bags for 1/2 trucks. Would these bags work for it or not? Also I don't know a whole lot about the whole air bag setup and where they locate to and what else nneds to be put in and done for them to work. I think the bags replace the coils but I am not sure. And also my rear end has coils and leafs, but im not planning on using my truck for hauling or towing so I figure I could just take one of them out. Well anyway... if anyone could educate me on the whole airbag setup that would be great and thanks for any advice.
Re: Airbaggin
There are a lot of bag talks in the suspension forum. I have never heard of a coil AND leaf rear, I didn't know that was even possible.
I would think the 1/2 ton kit would be the same as a 3/4 ton. The key is the rear end. If you have trailing arms with coils, you just replace the coils with bags (well, there is a lot involed, but that's the basic concept). If it has leafs, then you have a lot of options, but also a lot more work. |
Happy to be here
![]() Join Date: Mar 2000
Re: Airbaggin
I moved this to the suspension forum so you might get a better response. Take a look at www.ridetech.com and www.*****************. Air Ride Technologies has top quality products with tons of applications. Their quality is the best on the market. They aren't cheap, but they are good.
Suicide Doors has the budget builder in mind. They have lots of stuff for the do-it-yourselfer. Those are the two best companies that I know of to deal with.
what happened to flint mi
Re: Airbaggin
the coil leaf set up is supposed to be heavy duty , just get rid of the leaf part and its the same as a coil truck
71 swb 2wd fleet frame off in progress 72 4x4 blazer daily driver 70 olds cutlass s mint condition owned by a grandma 56 gmc 2wd project waitng 97 fiance mobile Last edited by tom71; 09-07-2006 at 11:10 PM. Reason: mis spell |
Junior Member
Re: Airbaggin
As far as it being a 3/4 ton... the only difference in the front is the ball joints, control arms bushings and the spindles and brakes. If it were me....
