Old 09-01-2006, 09:40 AM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Need more vaccuum for PB
I saw some place were you can add another canister to help out your power brake booster when you have a big cam. How do you hook some thing like this up?
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 09-01-2006, 10:52 AM   #2
LONGHAIR
Re: Need more vaccuum for PB
It is a simple cannister that you mount under the hood pretty much anywhere it will fit. It gets a vacuum line running to a fitting on the intake manifold. It ads volume to the vacuum system much like a larger tank on your air compressor. It makes the air last longer before it has to be replaced, keeping everything more stable.....less fluctuation.
It will not increase the vacuum itself. As in, you will not get more vacuum....it just makes what you have last longer.
LONGHAIR is offline   Reply With Quote
Old 09-01-2006, 12:29 PM   #3
1970 CST Short Wide
Senior Moment
So I just hook 1 line into a can from the intake manifold, No line out? Forgive my stupidity I'm just trying to understand. I get the more volume part I think.
It’s just storing vacuum in the can until its needed right ???
Pittsburg Ca
94565
Old 09-01-2006, 02:01 PM   #4
BarryB
BarryB's Avatar
Hey jumping in here, but to answer your question about the lines. You'll have one coming from your vacuum source( intake), and another one coming out of the canister and going to to brake booster.
Hope that helps.
BarryB is offline   Reply With Quote
Old 09-01-2006, 03:40 PM   #5
1970 CST Short Wide
Senior Moment
Do I splice into the brake booster line with a tee? Anybody done this and have pic's or a drawing. Will this help my power brakes due to big cam
Pittsburg Ca
94565
Old 09-01-2006, 03:41 PM   #6
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Just put a "T" in the line from your manifold to the booster, and run it to the canister.
sneakysnake is offline   Reply With Quote
Old 09-01-2006, 05:06 PM   #7
jacobs
jacobs's Avatar
Be sure to install a check valve inline between the new vacuum canister and the intake manifold, otherwise it you won't gain anything.
jacobs is offline   Reply With Quote
