Old 09-01-2006, 09:14 PM   #1
TP from Cntl PA
TP from Cntl PA's Avatar
Throttle Cables........
Are all the Stock GM throttle cables the same length for these year trucks(BB vs SB)? I put a 4brl on my inline and wanted to stay with a stock looking cable as I am attempting to make the whole works look like it "COULD" have been from the period when it was new..............The stock length cable works, but another 1" in length wouldn't hurt. Do I have to resort to the aftermarket for some chrome piece?
Did GM use the same style cable in later years that might be longer?
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 09-02-2006, 02:31 AM   #2
Brad
Out of the carpool lane.
Brad's Avatar
Re: Throttle Cables........
Sorry I can't help, because I'm at a point where I need to get a cable for my setup and wondering what to get. I hope someone will be able to help out there!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 09-02-2006, 07:35 AM   #3
I don`t know for sure about stock cables.But,I bet you could have one custom-made to appear "as original".
Old 09-02-2006, 07:40 AM   #4
70GMCer
70GMCer's Avatar
I know GM cars are different lengths......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 09-02-2006, 09:37 AM   #5
TP from Cntl PA
This isn't a project from trucks with an unlimited budget
Hmmmm, anyone with any concrete info on the ones in the cars? Granted mine will work for awhile, but I want to have something to replace it with when or before it fails
Old 10-01-2006, 02:10 AM   #6
Brad
Brad's Avatar
I'm resurrecting this thread since I'm now seriously looking for a cable approximately 24" long or less, preferably with the ball-stud mount, fits the 71-72 style pedal and is cheap.
Old 10-01-2006, 09:30 AM   #7
too much stuff
Roadtrip!
too much stuff's Avatar
You may want to see if you have a 2wd or 4x4, v-8 cable. I know they are different lengths. Not sure on the 6 cyl however...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 10-01-2006, 12:41 PM   #8
Bob Moore
You might look at a cable from a 73+ 6 cylinder PU.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 10-01-2006, 01:00 PM   #9
Mechdawg
Mechdawg's Avatar
I used two pieces of flat aluminum stock cut to the length I needed to go from the pedal lever to the carberator linkage held in place with some pins and retainers all from tractor supply.
Mechdawg is offline   Reply With Quote
Old 10-01-2006, 01:08 PM   #10
Mechdawg
Mechdawg's Avatar
Here is a couple pictures of what I did.Name:  PA010076.JPG
Old 10-01-2006, 01:10 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
he can't do that on his, he has a cable set up.
Old 10-01-2006, 01:14 PM   #12
Mechdawg
Mechdawg's Avatar
I see I thought 67-72 all used the same setup. Good to know thanks
Old 10-01-2006, 01:25 PM   #13
Longhorn Man
In 71 they went to a cable set up becouse of throttles getting locked open when the drivers side motor mount would seperate.
Old 10-01-2006, 01:30 PM   #14
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
One from a 79 Caprice looks to be the same style but is longer.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 10-01-2006, 03:42 PM   #15
TP from Cntl PA
The original is working for the moment, but I bet it goes with it gets cold. I may go with an aftermarket........Paint it black, because you can't hardly see it with the air cleaner setup I made.
Old 10-03-2006, 09:22 PM   #16
Don Smith
cables are diff lengths for 6cyl, 2bbl. and 4bbl. The 4bbl cable was exactly the correct length for my rod to cable conversion
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
Old 10-03-2006, 09:57 PM   #17
jimmydean
jimmydean's Avatar
This may have been aske before, but is it cheaper/easier to use a stock pedal and cable to convert my '69, or is there an aftermarket setup to do it? I hate the stupid bar thing.
Is all I need the pedal lever (mounts to firewall) and cable?
jimmydean is offline   Reply With Quote
Old 10-04-2006, 03:58 AM   #18
Brad
Brad's Avatar
Jimmy, not sure what you're asking for with the first question, but as to your second, I just did this recently and followed the write up and it's a piece o' cake! Just gotta drill a few holes and some grinding and bolt it right up. Btw, I have the bracket/pedal from a mid 70's C-10 if you're interested. I realized that it's virtually the same just more to the bracket. Seems like it would work well though.
