09-01-2006, 10:13 PM | #1 |
truck wont start need help please
72 k20 350motor turn the key nothing only the brake light comes on and the temp light dont come on all fuses checked good all the ones seen anyways ive got 12volts at the battery any info would be greatly app.
thanks jeff |
09-01-2006, 10:19 PM | #2 |
67-72 parts finder
Re: truck wont start need help please
check and see if you got power to the starter, maybe see if the fusable link is blown however i would think that nothing would work if that were the case
1969 chevy shortstep 2wd (under construction) 1981 chevy scottsdale lwb 2wd (parts chaser) 2004 pontiac gto (daily driver) 2004 pontiac grand prix gt (the ol ladys car) 1985 chevy short wide 1970 chevy c10 lwb (another parts rig) 1969 gmc lwb (rainy day project) 1968 chevy lwb c10 250 I6 3 spd (soon to be swb) |
09-01-2006, 10:21 PM | #3 |
theres power to the starter
09-01-2006, 10:26 PM | #4 |
67-72 parts finder
does it have a solenoid you can jump across??? also like i said try the fusable link located close to the battery
09-01-2006, 10:31 PM | #5 |
When you turn the key to start do you have power to both large terminals on the starter or just one?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
09-01-2006, 10:50 PM | #6 |
neonlary there is only one big terminal on the solenoid
lilpup yes it has a solenoid but it has two small post which do i use |
09-01-2006, 11:27 PM | #7 |
67-72 parts finder
damn without knowing i would just say guess it i know you'll use one big post one little one try it both ways either way its not gonna shock you
09-01-2006, 11:41 PM | #8 |
its also possible your battery cable has came apart inside and your not getting power to the starter the rest of the truck gets power of the other wire of the terimal that run to the juntion box on the fender right above the battery
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
09-02-2006, 04:00 AM | #9 |
given you have it in park and its a good starter. I'd say you should check for resistance
09-02-2006, 07:55 AM | #10 |
If it is an auto be sure and check the neutral saftey switch
09-02-2006, 07:56 AM | #11 |
If the truck is an automatic with column shift, i would say check the neutral safety switch, maybe hold up on the shift lever and try to start. but since its a 4x4 , i would asume its a stick shift, so that probably aint gonna help.
Have you had any indication of problems before now? maybe the starter not acting right before? if so i would suspect the solenoid, or the small wire going to it. i have had that wire burn in two inside the insulation, i couldnt tell untill i pulled on the wire and the isulation just pulled in two. thats where i would start. check that wire from end to end for continuity and if it shows good i would replace the solenoid. if that dont fix it then i would be stuck and have to ask somebody else. good luck, Tony
i survived cancer and kidney stones, but my kids are killing me. |
09-02-2006, 01:27 PM | #12 |
everyone thanks for your help i got the starter was froze up thanks again
jeff |
