Swapping 71 disc brakes on a 68 frame?
Hey guys, I need to know if the control arms are the same on the 71 and 68? I'm about to strip the 71 frame today, (for the 5 lug stuff), and wanted to see if the control arms needed to come off the 71 and go on the 68 frame or not? Thanks, Jason
Re: Swapping 71 disc brakes on a 68 frame?
ball joints are different, but the tuffest part is the tie rod ends. You need to make(fabricate) an adapter. heres a pic of what I did
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
Gone Fishing
When I did the swap on my 68 I just used all of the suspension parts off of the 71 so I didn't hace any problems
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
#4 | |
![]() Join Date: Mar 2004
i'm doing this very swap right now so here's the scoop.
71 upper and lower ball joints will fit in the 68 a-arms. you will need to swap the 68 ball joints for the 71 ball joints. i did this today. it took about 3hrs with disassembly. next you will have to do something with the tierods. 68 tie rods won't work with the 71 spindles and 71 inner tie rods wont work with the 68 steering link. you will either need to purchase and or make a tie rod adjusting sleeves or purchase these inner tie rods to use the 71 sleeves. Auto Zone part numbers ES403L and ES406L. good luck and btw here's the FAQ on this subject: http://67-72chevytrucks.com/vboard/s...d.php?t=160435 ondrew Last edited by roj2323; 09-02-2006 at 02:15 PM. |
I'm watching you!
I solved that...I have 72 disc brake front end with the 72 steering link. It's not ready to be installed yet but.....That'll work right?
Mike
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold ![]() |
Damn, I was told that it was a perfect swap, guess not?
![]() Join Date: Aug 2001
Why Not Just Swap The Whole Crossmember?? Then You Can Just Buy Replacement Parts For A 71. John
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
I BELIEVE 71 TO 68 IS A DIRECT BOLT IN SWAP. I'VE NEVER DONE A 71 OR 72 INTO A 67-70 PICKUP BUT I'VE DONE SEVERAL MID 70s TO MID 80s SWAPS INTO PRE 71 CHEVY TRUCKS. IF YOUR GONNA REBUILD IT THE TIME TO DO IT IS WHEN IT'S OUT & YOU CAN GET THAT SUCKER UP ON A BENCH, INSTEAD OF HUNKERED OVER OR LAYING ON YOUR BACK. I'VE DONE EM BOTH WAYS & ON THE BENCH IS ABOUT 3 TIMES AS FAST.
Here is a complete 72' front crossmember and on the board:
http://67-72chevytrucks.com/vboard/c...duct=251&cat=2 sorry...gues that is pick-up only...long ways. Last edited by ChevyDude; 09-03-2006 at 12:28 PM. |
#12 | |
Thanks, but I have a complete 71 long bed in my yard ![]() |
#13 |
Active Member
![]() Join Date: Dec 2005
Help! I followed the directions above to swap 71-72 discs into my '67. The 67 drag link seems to be the rub with its smaller (than 71-72) hole for the tie rod. Just got back from Autozone and they have discontinued the ES406L inner tie rod that is mentioned in this thread and the referenced FAQ. They still stock the ES403L which I purchased.
Can anyone tell me the application for the Autozone ES406L inner tie rod end so that I can see if another supplier has something like it?. The guy at the counter couldn't tell me. Now there's a surprise! Thanks!!
The older I get, the faster I was!! |
#14 |
well i hate to tell you, i done this swap and a nother board member here told me so if you do a search you can be for sure. I boght a custom adjusting sleve from cpp they can tell you wat all you need, i can't rember if it is shorter or longer but i think you use 71-72 outers for the outers, and 68 outers for you inners, i know it looks very good once installed and that sleve looks awsome. call classic performance products and they lead you the right way. ill have to tell you though once you buy all the new tirods and new sleves. your wallet will be empty. i think i came in around 200.00 dollars
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
#15 |
Problem solved!!!
#16 |
