09-02-2006, 07:45 PM | #1 |
rusted bed side bolts.........
I am trying to take apart a 67 fleetside bed. It is in pretty good condition but I want to take it apart so I can clean it all up do some small repairs.
The problem is, I don't have a welder other than gas and no air. The nuts under the bed are rusted so they won't take a socket. I have tried torch.........no good, no room, chisel, wearing me out, prying and after 6 hours and only 9 bolts, came home and here I am asking for advice........... Thanks, Steve |
09-02-2006, 07:49 PM | #2 |
Re: rusted bed side bolts.........
just try tightening them they should break pretty easy
09-02-2006, 08:09 PM | #3 |
Member #1049
Wow can't even get a socket on them? I normally use a 6 point 1/2 drive socket and ratchet and just tighten them up and bust them off.... One "other" way I have removed them is to center punch the heads and drill em with a bit just a tad larger than 5/16".. Or find the tool called the "nut buster" but that's hard to get into some of the nooks and crannies where some of the carriage bolts are...
09-02-2006, 08:21 PM | #4 |
Never thought to tighten them........try that tomorrow.
The bed isn't rusted but the bolts look like they melted.......not torch or anything like that. They were packed with sand, got the bed from just below Dallas and it came from Mexico. I will try using a metric 12 point, Craftsman of course, and tighten them. thanks, Steve |
09-02-2006, 08:38 PM | #5 |
the oyher thing i've also done is using a 3"cutoffwheel in a die grinder ground down the heads / but you have to have a real steady hand to noy damage the sheetmetal/ you just grind it down about 95-98% then you can center punch them thru the hols
09-02-2006, 08:49 PM | #6 |
Member #1049
The 12 point socket may just "slip" on the rusty nuts.. try a 6 point if at all possible.. more gripping power.. Preferably a "taiwan" cheapy and beat it on with a hammer if needed
09-02-2006, 09:02 PM | #7 |
The only reason I was thinking a 12 was because there really aren't any flats on whats left of the nuts
09-03-2006, 08:56 AM | #8 |
Doesn`t Bob Villa have a wrench for that?Someone write him a letter.I drill,like Livrat,or grind,like CDowns.If the right-angle grinder won`t get on it,try a drill or cut-off/die-grinder tool.
09-03-2006, 10:47 PM | #9 |
YA YA
For some of them I used a cut off wheel to cut a slot and then held the bolt with a flat head screwdriver while the wife used the impact to back the nut off. Others I had to do what cliff mentioned and grind the head completely off and punch it through.
Jimbo '72 SWB - 350 (frame-off resto in progress - donations accepted) '04 Chevy Avalanche '03 Cadillac CTS (wife's ride) Restoration progress - http://67-72chevytrucks.com/vboard/s...d.php?t=335707 |
09-03-2006, 11:20 PM | #10 |
no air and no help! I was able to break a few more off.......
09-04-2006, 12:12 AM | #11 |
I have a bed side that the bolt spin in because the hole was rusted. I used a cut off whell and punch method. Now I just need to patch the holes and bolt it on my truck.
09-04-2006, 12:48 AM | #12 |
Best thing since sliced bread--a set of Sears damaged bolt remover sockets.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
09-04-2006, 10:51 AM | #13 |
ah, now that will work........hows my 56? LOL
Thanks |
09-04-2006, 11:15 AM | #14 |
I'm also a fan of the grinding/cutoff method. An air hammer makes a nice center punch.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
09-04-2006, 02:25 PM | #15 |
Still MINE!
09-05-2006, 07:46 AM | #16 |
Junior Member
Sears damaged nut removers have work well for me many times. I used them to get the header panel off my bed a few months ago!
09-05-2006, 08:28 AM | #17 | |||
Union Electrician
I drilled almos all of mine out, was faster and easier imo than cutoff method. Drilled the whole bed apart in a couple of hours. I think I used a 3/8" bit iirc
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
09-05-2006, 08:24 PM | #18 |
It is apart...........finally. I wish I hadn't sold my compressor
