The start of the $ pit!
clean and polish trim pieces
Anyone got advice on how to clean and polish the trim pieces on the grill?
Re: clean and polish trim pieces
Which grille are you referring to? GMC, Chevy, year?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
Not sure why it would matter but it is a 68 Chevy c10. I am only talking about the trim rings around the openings in the grill and the headlights. All other trim has been removed and welded up solid.
![]() Join Date: Mar 2003
I use 0000 steel wool and wd 40
