Old 09-03-2006, 01:14 AM   #1
tom71
what happened to flint mi
tom71's Avatar
do you have a air suspension plumbing diagram
i am a bit lost as to how plumb the system id like to get types of fittings used and the number of them used too thanks . tom
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 09-03-2006, 01:26 AM   #2
jimmydean
jimmydean's Avatar
Re: do you have a air suspension plumbing diagram
I have at least a dozen different diagrams, all use different fittings and valve placement.
I figured out today that my tank will mount in the rear of my frame, so I will run my hoses from there. I am also mounting my valves on the frame rails near the bags they work. By having all the valves near the bags, they will fill faster.
I hope to get my crap started in a week or two and I will post pics then.
jimmydean is offline   Reply With Quote
Old 09-03-2006, 01:29 PM   #3
jasonrmorrow
I just went through this this weekend. I ended up with around 40 fittings, and i'm manifolding them off the tank.
I had to use some extra fittings and stuff because the big rig shop didn't have every "optimal" fitting but it all fits together, i'll take a picture of my tank when its done, have to go get 4 more fittings because i used a plain tee instead of a street t so i have to run a nipple between the two. oh well. They're 5 mins away, i'll get a pic up later today.
I would like to see some real #'s as to how much faster the bags fill with valves near the bag, not trying to dispute anyone just want to know, i'm also running 200 psi in the tank, that should push the air faster. I better get to work though...
Go here...http://www.bagginit.com/TechnicalInfo#fittings
scroll down to the FITTINGS DIAGRAMS, thats how i set up my valves. I just added to the "tee" for gauges.
1964 - LWB 350 TPI Fuel Injection
On airbags
jasonrmorrow is offline   Reply With Quote
Old 09-03-2006, 01:47 PM   #4
tom71
tom71's Avatar
jason whats the diff between a street t and a regular tee fitting ? thanks for the link
97 fiance mobile
Old 09-03-2006, 04:38 PM   #5
jasonrmorrow
Just hit this link...http://www.*****************/Fittings.php
Street tee allows you to tee an existing port by threading the tee into the port which is what i had to do becuase the supplier didn't have any "crosses".
Or i could have bought a brass tee with 1/8 inch gauge fitting but those are custom made by suicide doors, it makes for a cleaner setup but mine is still functional just a little bulky.
On airbags
Old 09-03-2006, 10:45 PM   #6
jimmydean
jimmydean's Avatar
Not sure if I will notice any difference, but with the tank I got I didn't want to hang the fill valves off of it.
So for easy of access, I am mounting the fill/dump valves on the frame right outside of each bag. My first design was to mount the fill valves to the tank, then the dump valves near the bags, but I didn't like the idea of the valves hanging off the tank.
Old 09-03-2006, 10:51 PM   #7
7deuce
Sold! 2 days after finished
7deuce's Avatar
No matter where you put the valves you should fly up with 1/2 in valves and line. I reduced my back to 3/8 because it was WAY to fast for me. If you were to sit on the tail gate it would blast you off. NO NEED. Unless your going to hop it. And as far as mountint the valves to the tank. Just use a black pipe nipple not brass comming out of the tank. Brass will and has cracked when used there.
7deuce is offline   Reply With Quote
Old 09-06-2006, 12:54 PM   #8
Slammed67
Progress = 0%
Slammed67's Avatar
Here are some diagrams I drew up... might help you out....
air-ride-diagrams
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 09-14-2006, 10:32 PM   #9
tom71
tom71's Avatar
thanks slammed 67
97 fiance mobile
Old 09-14-2006, 10:34 PM   #10
Shane
Shane's Avatar
hey Jason ... where you been hiding?
Shane is offline   Reply With Quote
Old 09-15-2006, 01:05 PM   #11
jasonrmorrow
No where special...whats up ?? Did i forget something ?
On airbags
Old 09-15-2006, 01:32 PM   #12
Shane
Shane's Avatar
wrong jason
Old 09-15-2006, 02:51 PM   #13
jasonrmorrow
As i walked up to the computer this time i was thinking the exact same thing...I wonder if theres a different Jason in this thread...
thanks for not caring !!!
On airbags
Old 09-15-2006, 03:22 PM   #14
Shane
Shane's Avatar
lol ... not that I don't care, just havent' seen Slammed67 post in a while and was wondering where he had been.
Sorry I sounded "uncaring."
