Old 09-03-2006, 09:36 AM   #1
pdr510
Junior Member
pdr510's Avatar
Smile Post your fuel filler pics
I am in the process of installing a blazer tank in my '70 C-10 stepside. I would like you to post your fuel filler pics. I have seen the side marker light filler here that looks nice.
pdr510 is offline   Reply With Quote
Old 09-03-2006, 10:08 AM   #2
chevyboy55
chevyboy55's Avatar
Re: Post your fuel filler pics
Here's one it's not a real good one.I don't have one with the light all mounted up as the truck is not finished yet.
chevyboy55 is offline   Reply With Quote
Old 09-03-2006, 10:14 AM   #3
pdr510
Junior Member
pdr510's Avatar
Looks good. How hard is it to get the gas cap off?
Old 09-03-2006, 07:22 PM   #4
chevyboy55
chevyboy55's Avatar
Easier than it looks by the pic.
Old 09-03-2006, 09:39 PM   #5
Mudder
Mudder's Avatar
This is a 4x4 and theres more room between the bed and the frame than yours. Bottom two is a friends.
Mudder is offline   Reply With Quote
Old 09-04-2006, 12:37 AM   #6
QKENUF4U
QKENUF4U's Avatar
heres mine
QKENUF4U is offline   Reply With Quote
Old 09-04-2006, 12:51 AM   #7
hotrodhomi
hotrodhomi's Avatar
Originally Posted by QKENUF4U View Post
heres mine
Do you have problems filling the tank from the gas pump at full blast? It looks good. I've been think of alternative ideas because I have problem filling my tank (slow or fast)
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 09-04-2006, 09:49 AM   #8
matthufham
i redesigned mine many times. the last one i thought was perfect until i connected the hose from the filler to the tank then it wouldn't flow into the tank because it had to fight gravity. i ended up putting it in the wheelwell so it's a straight downhill shot at the tank. the filler is from a 77 chevy truck.
the 1st 2 pics are from the 77 i took the filler from, i took the bedside and was going to use the door function and put it on the rear of the drivers inner bedside. i had a clearance issue with the sidemarker light, 1/16th of an inch, and i didn't want to shave the sidemarkers so i scrapped that idea.
later i did shave the sidemarkers so i should of kept that idea
then i decided to keep the filler where it was cuz i already had a hole in my inner bedside and made a box for it to sit within. (pic 3)
i cut that up in the rough stages, then i made and angled piece in the bed.. i liked that one but didnt work
matthufham is offline   Reply With Quote
Old 09-04-2006, 10:11 AM   #9
John Fabris
TOTY 2006
John Fabris's Avatar
here a shot of what I did for my rear tank filler...
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 09-04-2006, 10:26 AM   #10
Shane
Shane's Avatar
nice work Mr. Fabris ... now I gotta figure out how to do something similiar in a step bed.
Shane is offline   Reply With Quote
Old 09-04-2006, 10:44 AM   #11
pdr510
Junior Member
pdr510's Avatar
Nice work! Wish I could do my stepside like that.
Old 09-04-2006, 02:28 PM   #12
hotrodhomi
hotrodhomi's Avatar
That looks nice. To bad I need to put the top on my blazer.
'66 impala ht
Old 09-04-2006, 02:56 PM   #13
6(sic)6
6(sic)6's Avatar
John Fabris : what kinda cap is that? i like the way its "flush" id love to do somthing like that to mine, and also have my bed cover on it.
Daily Driver:
383 sbc
Shaved.
lowerd
6(sic)6 is offline   Reply With Quote
Old 09-04-2006, 03:20 PM   #14
John Fabris
TOTY 2006
Its a marine gas filler. Go to any boat store and they can get it for you. Costs around $50. The rectangle part is what you push and it pops up, then you can unscrew it.....
John Fabris
67 C10 SWB
Old 09-04-2006, 03:24 PM   #15
70short/step
70short/step's Avatar
You can also buy a pop-up gas tank cap that mounts flush and can be painted body color. I have only seen it for motorcycles and custom bikes. try biker shops for one. There are awesome
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 09-04-2006, 03:27 PM   #16
LeftEar55
Me too, that's really nice! Mounting it that way, I wouldn't have to cut up my floor or mount the filler in my fender... Also, to everyone else, will a Blazer tank be just as good as one of these $500+ alloy tanks, for someone like me not trying to make a show truck? I just can't see spending $500+ on an alloy tank, when I can spend $200 or so and get a Blazer tank...
LeftEar55 is offline   Reply With Quote
Old 09-04-2006, 03:27 PM   #17
chevybill
chevybill's Avatar
Have any of you guys used radiator hose to connect your filler to your tank or have you purchased hose specifically for gasoline?
I had an autozone guy say that radiator hose would stand up to gas and work for this application as long as the curve is not to severe?
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 09-04-2006, 03:49 PM   #18
byrd
Union Electrician
byrd's Avatar
Leftear, on a shortbed truck when using the blazer tank you will have to trim the most rear crossmember on the bed itself to let the filler spout on the tank clear the frame and bottom of the bed.with the one from fuelcell guy on here you do not have to trim or modify anything, other than providing a filler location.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 09-04-2006, 03:53 PM   #19
wibilly
wibilly's Avatar
Heres mine, 40 gallon suburban tank in a short box...
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 09-04-2006, 04:31 PM   #20
timcos
Chief Honcho In Charge
timcos's Avatar
Alrigth Wibilly...that is the coolest thing I have ever seen. remonds me of the batcave.
Do you have any construction/fab pics?
Any hints/tips on the 40 gal suburban tank and installation?
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 09-04-2006, 09:01 PM   #21
wibilly
wibilly's Avatar
thanks, timcos i do have more photos somwhere i just took these today to post here. i'm pretty much computer illeteret so i'll have to get my daughter to get them togather and post them
Old 09-04-2006, 09:57 PM   #22
see ten
WTB this ad
see ten's Avatar
Spend the $ and buy the fuel line that is made for the job. It's not exactly cheap but you will get what you pay for. Oh and we always know how the Autozone guys have good intentions!
see ten is offline   Reply With Quote
Old 09-04-2006, 10:07 PM   #23
CMars45000
CMars45000's Avatar
DEF. BUY THE RIGHT STUFF... The stuf is like $12 a foot but it is worth it and Napa just came out with it available in a 45-degree and 90-degree andle in a few different sizes...
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 09-04-2006, 10:11 PM   #24
byrd
Union Electrician
byrd's Avatar
Sweet, gotta love Napa
Zip:40272
Old 09-04-2006, 10:21 PM   #25
SactoJim
SactoJim's Avatar
Here's my "before and after".
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
