Old 09-03-2006, 02:42 PM   #1
roj2323
6 lug rotor suppliers?
hey guys,
i am currently swaping my 69 front drums for 71 disks and i was hoping someone may know where i can get 6lug rotors. i know ECE supplys them but does anyone else?
ondrew
roj2323 is offline   Reply With Quote
Old 09-03-2006, 03:13 PM   #2
poorboy
poorboy's Avatar
Re: 6lug rotor suppliers?
McGaughy's has them. The kit is $239. It includes everything but the spindles.
poorboy is offline   Reply With Quote
Old 09-03-2006, 03:14 PM   #3
poorboy
poorboy's Avatar
www.mcgaughys.com 559-226-8196
Old 09-03-2006, 03:22 PM   #4
roj2323
i allready have everything else. all i need is rotors.
Old 09-03-2006, 03:41 PM   #5
poorboy
poorboy's Avatar
I would give them a buzz. Maybe they will sell them seperate.
Old 09-03-2006, 03:45 PM   #6
qksilver
They are basically 5 lug late model (73-87) rotors that they redrill to a 6 lug pattern. Many different after market suppliers. I remember a while back that someone used like 95 heavy duty half ton rotors to do a swap. Not sure if they will go on the spindles you have unless you sue different inner wheel bearings. I think it was dennis brooks who did it.
I would check with one of the board vendors I know they carry them.
qksilver is offline   Reply With Quote
Old 09-03-2006, 05:48 PM   #7
SCOTI
SCOTI's Avatar
Re: 6 lug rotor suppliers?
GMC Pauls sells 6-lug rotors that are a direct swap to the 5-lug disc spindles. Theirs are not re-drilled though. From what I understand, they get them as 'blank' rotors & have them drilled w/the correct 6-lug pattern from the start.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-04-2006, 12:28 AM   #8
pickupman
pickupman's Avatar
I also have them available as well.
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 09-04-2006, 08:35 AM   #9
dallas71
dallas71's Avatar
pickupman.....how much are they???
dallas71 is offline   Reply With Quote
Old 09-04-2006, 09:38 AM   #10
pickupman
pickupman's Avatar
Just the rotors run $175 for the pair
Old 09-18-2006, 07:19 PM   #11
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
This might not apply to this thread but I will try...
How about 6-lug truck rear disc rotors ...
I have seen newer trucks from GM using rear disc brakes.
What is available in this application?
Thanx!
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
