Old 09-03-2006, 05:17 PM   #1
69 air cab
going from 6 lug to 5 lug
anyone have any suggestions on the best (easy and lowest cost) way to change my 69 C10 from a 6 wheel lug to a 5 lug? Is it better to change the rearend all together?....and if so what should I use. I also plan to add disc brks on the front and drop it so I guess the lug change can happen on the front then.......correct?
69 air cab is offline   Reply With Quote
Old 09-03-2006, 05:34 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: going from 6 lug to 5 lug
Probably the most economical way is to find a later model donor truck that you can swap the parts from. Locate a rusted or wrecked truck that can be bought for cheap, swap all the parts and sell anything left to recover your money.
The 73-87 crossmember swap is pretty common. The rear is a different story due to width. I "think" 69 was the transition year that had two different widths. I'm sure some of the resident 67-72 experts will stop in and clarify that for you...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-03-2006, 05:41 PM   #3
SCOTI
SCOTI's Avatar
Changing to 5-lug up front is a simple disc brake conversion. For the rear bolt pattern, you can:
1) Re-drill the original axles & use 71~72 drums. This would be cheapest but then you'll still have 30+ year old axles.
2) Swap in a later rear w/the correct bolt pattern. If you can get another rear end cheap & you can do some med difficulty fabrication (or know of a shop to do it for you) yhis can be a cost effective alternative.
3) Or..... swap the axles w/new upgraded strength axles that are the correct bolt pattern & use 71~72 drums. There's several vendors that sell '6 to 5-lug' conversion kits. This is not only is the easiest to do, you get brand new higher quality/strength axles in the process.
Choice # 3 would be what I suggest.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-03-2006, 05:42 PM   #4
lilpup69chevy
67-72 parts finder
lilpup69chevy's Avatar
i heard from a person who has done the swap before so don't quote me on this but he told me that 70 had the wider rearend
1969 chevy shortstep 2wd (under construction)
1981 chevy scottsdale lwb 2wd (parts chaser)
2004 pontiac gto (daily driver)
2004 pontiac grand prix gt (the ol ladys car)
1985 chevy short wide
1970 chevy c10 lwb (another parts rig)
1969 gmc lwb (rainy day project)
1968 chevy lwb c10 250 I6 3 spd (soon to be swb)
lilpup69chevy is offline   Reply With Quote
Old 09-03-2006, 05:44 PM   #5
SCOTI
SCOTI's Avatar
From what I've experienced & from what others have discussed, the width change occurred sometime during the 70 year model so some could possibly still have the 'shorter' 67~69 rear.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-03-2006, 05:52 PM   #6
lilpup69chevy
67-72 parts finder
thanks for clearing that up scoti, guess the best way would be to measure it and find out what ya got
Old 09-03-2006, 06:18 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
So 1970 was the transition year? I didn't miss it by much...
Articles-
"Refining Sierra"
Old 09-04-2006, 10:34 AM   #8
69 air cab
So Scoti..........do I have to pull the axle to redrill it? Sorry for what might be a dumb question but I am not an axle guy.
thanks
Old 09-04-2006, 11:47 AM   #9
roj2323
i've been looking into the redrilling the rear axles and it's not as simple as drilling a couple holes. no matter how you place the 5 lug drum on the 6 lug axle the holes tend to overlap. since the holes do overlap the old holes will need to be welded in before you can drill. also the centering flange "or whatever it's called" is too big to fit the 71 drums. it needs to be turned down around 11mm to fit the drums. by the time it's all said and done, unless you have a machine shop, it's cheaper to just buy replacement axles.
ondrew
roj2323 is offline   Reply With Quote
Old 09-04-2006, 12:19 PM   #10
Robznob11
Robznob11's Avatar
i bought moser axles with 1/2 screw in studs for my rear for 280.00 to the door, you can get a little cheaper if you buy regular studs.. some places offer cheaper axles too but mine are 40% stronger than stock and non tapered!!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 09-04-2006, 03:27 PM   #11
SCOTI
SCOTI's Avatar
Originally Posted by 69 air cab View Post
.... do I have to pull the axle to redrill it? Sorry for what might be a dumb question but I am not an axle guy.
thanks
Yes, the axles are pulled to re-drill the bolt pattern.
Only 1 of the holes will need to be plugged (welded up) before redrilling. The rest can be drilled when you rotate the pattern slightly (that's how my original axles were done). Yes, the axle 'hub' will also need to be cut down slightly as well.
This is how I went the second time around. I wasn't to pleased w/Moser as the splines were not quite right so it was frustrating getting the issues worked out (they lost my spider gear & said I must not have put it in the box yet it was taped to the axle to keep the 2pcs together..... & they got the axle!).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-04-2006, 06:09 PM   #12
dennislbrooks
dennislbrooks's Avatar
If I do another set, I would only weld the single hole that has to overlap.
http://67-72chevytrucks.com/vboard/s...d.php?t=163480
dennislbrooks is offline   Reply With Quote
Old 09-04-2006, 06:47 PM   #13
junkyardjohn
junkyardjohn's Avatar
I Have A 9" Ford Rear End Out Of A 75 Mkiv For My 72 1/2 Ton Project . I Had It Rebuilt With A Possi Center Section & A 355-1 Ring & Pinion. They Came Stock With A 5 On 5 Boltpattern (same As Our Trucks) & It Has Disc Brakes. The Rear End Was About $80 Out Of A Boneyard & I Bartered With A Guy That I Knew That Owned A Driveline Shop To Rebuild It. John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
