Old 09-04-2006, 01:49 AM   #1
Green Machine
Green Machine's Avatar
Fuel filter by the carb or by the pump ???
Have to run a new fuel line between the pump to feed the edelbrock carb. It would be easier to put the filter by the carb, but the big metal filter might pick up a lot of heat from the intake. I was thinking of mounting it up and down near the pump. Anyone have some pics or suggestions ??? I don't want to have any more rubber line than needed or extra leak spots either - Thanks.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 09-04-2006, 02:10 AM   #2
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Fuel filter by the carb or by the pump ???
i run a small metal filter on the line from the pump to the carb and mine goes infront of the engine and the hoses and over the upper heater hose but i put another peice of bigger hose around the fuel line so it wont get to hot sitting on the heater hose and works fine for me plus i figured if the fan blows on it it might keep it cooler than sitting off to the side or something anyway i hope that helps any
-steven
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
