09-04-2006, 03:38 PM | #1 |
chevy truck fan
thermastat housing leak!!
well i must turn to you professionals again. i have a edelbrock air gap manifold on my 383(350) & i bought i chrome neck from my local autozone. i can't seem to get it to not leak!!! it is really frustrating anyways i have cleaned it off & tried to put it back on again & i still have a leak!!!
i want to keep it chrome so my engine will look nice. can you guys please tell me what you have done & or tell me some ideas to try to keep it from leaking i have put gasket maker on both sides of the "rubber" gasket & same result. any help would be much appreciated. thanks!!! rodstored-72 |
09-04-2006, 03:44 PM | #2 | |||
Union Electrician
Re: thermastat housing leak!!
I had the same problem, get a chrome one with a O-ring gasket instead and that will fix it right up.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
09-04-2006, 03:52 PM | #3 |
exactly the experience i had// those cheapo thermo housings are a waste of money look to be spending $20-$25 for a good problem free oring unit
09-04-2006, 03:53 PM | #4 |
-Chris
Ive always heard of people have problems with these things but I just put on the neck with the o-ring and a little gasket sealant and it works fine. Best of luck to ya with it.
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt. BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481 2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's 2017 Chevy Suburban (Wifes Car) - Fully Loaded & Stock "Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem." Ronald Reagan, President of the United States; 1985 |
09-04-2006, 04:01 PM | #5 |
67-72 parts finder
heck i used the one with the o ring and a housing gasket as well just don't overtigthen it and i never had any leaks, a little gasket sealant goes a long ways lol
1969 chevy shortstep 2wd (under construction) 1981 chevy scottsdale lwb 2wd (parts chaser) 2004 pontiac gto (daily driver) 2004 pontiac grand prix gt (the ol ladys car) 1985 chevy short wide 1970 chevy c10 lwb (another parts rig) 1969 gmc lwb (rainy day project) 1968 chevy lwb c10 250 I6 3 spd (soon to be swb) |
09-04-2006, 04:03 PM | #6 |
what happened to flint mi
the chrome keeps it from sealing correctly if you scuff the chrome where the gasket sits you mite have better luck .
71 swb 2wd fleet frame off in progress 72 4x4 blazer daily driver 70 olds cutlass s mint condition owned by a grandma 56 gmc 2wd project waitng 97 fiance mobile |
09-04-2006, 04:27 PM | #7 |
had a chrome one on mine for a 1000 or so miles and replaced it last week casue it was leaking (pretty much from day one) and the chrome was bubbling off. i bought a stock style from CHECKERS for 12$ and not a leak to speak of.
good luck |
09-04-2006, 04:33 PM | #8 |
Location: vacaville ca, because it as far from indy as i can be
the chrome ones suck, even the o ring t/d, pro form or whatever the hell the brand is from kragen, they are weak and easily over tightend and alwasy leak. the gasket style is less likely to bend because it has a flat surface to flat surface mate, the o ring style has to pinch the o ring down and it will flex over the top of the o ring.
09-04-2006, 05:08 PM | #9 |
Biggest problem is they get overtightened. They will pull up in the center and leak. If you take them off and put them against a grinder wheel, you can see the middle isn't touching. You can "mill" it flat and try again. It's only holding water, no need to get out the muscle.
09-04-2006, 05:15 PM | #10 |
09-04-2006, 09:29 PM | #11 |
I went through 3 or 4 cheap chrome ones before I gave up. If they don't leak to start with they will eventually. The cheap material will even corrode away to nothing. Put a nicely painted stocker back on, no more problems.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop 70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress |
09-04-2006, 11:19 PM | #12 |
Broke and still trying
Put a stocker on it and get it coated if you want it to look nice. The chrome one I have leaked from day one for me.
09-04-2006, 11:44 PM | #13 |
18 Till I Die
try something like this
http://www.jegs.com/webapp/wcs/store...tegoryId=10129 I did find one alot cheaper and it was the same, mabey ebay
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
09-05-2006, 04:04 PM | #14 |
chevy truck fan
all,
thanks!!! i think i am going to try to get a new housing. probably the billet specialties item. rodstored-72 |
09-05-2006, 04:21 PM | #15 |
Rolled on Paint Club
Put RTV Blue on the bolt threads too. Dont some of those threaded holes go into the water jacket on some of those aluminum manifolds?
Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
09-05-2006, 05:53 PM | #16 |
I discarded the o-ring and filled the groove with black high temp RTV. Put a thin coat on intake and housing and cured my leak.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
09-06-2006, 10:47 AM | #17 |
chevy truck fan
Thanks Again For The Great Help. I Guess I Will Try What You Said Green Machine. It Just Makes Me Sooo Mad That I Have To Do All This Over Again & Now I Have To Clean Off The Fitting & Manifold To Boot!! I Just Wish Things & People Would Make Something Right! What Happen To The Days When People Took Pride In Their Work Or When They Were Doing Something For Someone (ie: Auto Repair - Mechanics). It Seems Like When You Want Something Fit Right Or To Be Done Right You Have To Pay Extra!!!
Well Anyways I Guess I Will Try To Fix The Leak..... Again! Thanks Again For All Your Help!!! Rodstored-72 |
09-18-2006, 01:56 PM | #18 |
Any one know what the part number for a stock 350 housing is with no pipe holes in it?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
