Old 09-04-2006, 03:50 PM   #1
firemanmsmith
Pulling Engine Tran and t-case
I am buying a '70 C10 w/ 350, TH350 and NP205
I will be swapping the motor and tranny. Can I pull everthing together? I have been told that with the 205 you cant pull everything at once. Thanks for any help ahead of time. Mitch
firemanmsmith is offline   Reply With Quote
Old 09-04-2006, 07:48 PM   #2
JAKES 68GMC
Aluminum slot wheels rule...
Re: Pulling Engine Tran and t-case
It would probably save you a lot of time if you just unhooked or pulled out the t-case instead of trying to pull them all at once.
JAKES 68GMC is offline   Reply With Quote
Old 09-08-2006, 03:22 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
I pulled my 69's 307, 3 speed manual and Rockwell T221 as one unit. I had the front clip off. It was a bit of work to get the transfer case off it's crossmember and snaked out but possible.
P.S. Wasn't it nice of my friends to let me grab my camera and take the pics as they yanked and pulled
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
