Junior Member
![]() Join Date: Oct 2003
1967 327 Spin on Oil Filter number?
My 1967 C20 with a 327 has a spin on type oil filter. I think it is a conversion from the original can type filter but I am not sure. I purchased a Wix brand filter from NAPA that was supposed to fit. After the oil change, oil is leaking from around the filter. I noticed that the old filter was different than the new but did not think much of it when installing it.
Now the old filter has been taken away by the trash people and I do not know what the number was. Does anyone have a filter part number that works for the 327s? I prefer Fram but I should be able to convert any brand. Thanks, Paul |
Active Member
Re: 1967 327 Spin on Oil Filter number?
Sorry can't help you with the Fram #, but my '68 307 which was converted from cartridge, to spin on on has a Purolator L20049 on it.
![]() Join Date: Jul 2004
The kits I have seen use either the common Chevy filter or some use a F*rd filter, the common older v8 F*rd filters. I think the Wix # for a F*rd V8 is 1515 ???
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
![]() Join Date: Nov 2004
Don't know if this will help or not, but for the older 350's the Fram number is PH5, I don't see why a 327 would be different?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
its all about the +6 inches
a 1060 NAPA filter fits normal old school small blocks, if there is an adapter involved, there's no tellin.
However, putting a fram filter on there is the absolute worst you can do in oil filter selection. They put money into adgertising instead oif filtering media. There andi drain back valve is junk (doesn't matter on these engines though) but the filtering media is not nearly enough. I'm not saying that your engine will blow up if you spin one on there, BUT, I am pointing out that most of the automakers (including ALL of the big 3) had charges filed against them by Fram. They all knew what junk fram was putting out, and were turning away waranty work for blown engines stating a junk oil filter. (only brand filter that they were doing this to) And, I'll also say, if you were to call ANY indipendant oil lab anywhere in the US, they'll agree with everything I just typed. Fram sucks. |
instead of tryin to matchup oil filters it maybe cheaper and take less time to just buy a new adapter with the proper filter// any auto parts store should have them in stock i prefer NAPA OR CARQUEST for these types of items
#7 | |
Gone Fishing
![]() Quote:
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
![]() Join Date: Sep 2005
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
I seem to remember the Fram spin on was PH8-A . Napa gave me a 1061 for my 350. It's the wix equivalent. I gotta believe your adapter is bad or the filter was over tightened.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
![]() Join Date: Mar 2003
The adaptor on my 68 GMC takes a ford filter napa 1515
"Ochre Ogre"
The adaptor I had on my old SB chev used the "one size fit all Fords" back in the 60's and 70's. If memory serves me correctly, the Ford # was the FL-1A with the old numbering system. The Silver Napa filter is the 21515 aka 1515.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
Junior Member
Thanks for the information. I will look into the Ford Filter. I also found a new adapter and filter at LMC. It is less then $20.00 so it may be worth it. I tried a few other suppliers but can not find one anywhere else. I hate to order from them since I have not heard many good things about their service but it is always fun to gamble right?
I have also heard negative things about Fram. I still need to cut one open and look inside. I work for GM and have been involved in developing field fixes. 20 years ago, GM recommended Fram since their filter helped cold start knock. Now I have heard that they got really cheap and are the worst. I may try and cut up a few filters myself and compare the media to see if there really is a difference. With global sourcing do we really know who makes what part and where they are made? I shy away from Delco since one may be made in US and the "identical" one next to it is made in China. They are the same but different. When I get around to my experiment, I will try and take pictures for all to see. Paul |
#13 |
Just need a couple more parts.
I have a 327 (not sure what year it was from) in my truck and I am 98% sure that I have a PH5 oil filter on it.
--------------------------------------------------- 1947 Studebaker M5 project to match the camping trailer. 1950 Chev 4x4 Pickup 1958 Shasta Airflyte Travel trailer (fresh restoration) 1971 C/10 Pickup(Frame off Restoration) 1972 K5 Blazer CST (Daily Driver & My Company Truck) 1976 Honda CB750 Bobber 1988 Jaguar XJ12 |
#14 |
Before I knew about fram being junk, i ran a PH13.
A great filter to use is the Napa gold. They are made by WIX, and are not seconds or anything, they are simply rebadged (as is lots of NAPA stuff). It is pretty much the best for the money. |
#15 |
Formerly yellow72custom
IIRC, the Wix filters for a SBC are 51060 with drainback valve, and 51061 without a drainback valve. But its been awhile since I've bought one. I always by Wix filters for my vehicles, although for whatever reason they have been black for a year or so now...
No NAPA's around here so no NAPA parts.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
#16 | |
Not a bad nut after all..
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
#17 |
Same with the premium Carquest filters. They say "made in the USA by Wix" a couple different places on the box.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
#18 |
Wow... i did not know that.
#19 |
Junior Member
Nice information on the oil filter website. Thanks for sharing. Paul
#20 |
napa had two filters cut open on the counter the other day one fram and a napa gold after seeing this i will never use another fram, ever, on anything
common sense isn't so common anymore |
#21 |
Just hang'n around
Wow, glad I have a WIX dealer just down the road.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year. |
#22 |
Active Member
All it took for me to kick the fram habit, was to hold a fram in one hand, and a purolator in the other. The fram felt like a empty tin can, while the purolator felt solid, and weighed a good bit more.
