Old 09-05-2006, 04:06 PM   #1
bulkin'up73chevy
bulkin'up73chevy's Avatar
busted ignition
hey guys this is my work truck and I have to get to work with it. Someone tried to take it and busted my ignition out and then couldn't get it to start so now I need to know which wires to cross to hotwire my truck asap. I own the truck and I run my own business. So please help me out.
FAMILY MAN
77 CHEVY LB 4X4
78 GMC LB 4X4 "TOWED AWAY"
77 GMC FLATBED 502 CADDY BB.
85 CHEVY BLAZER (wrecked)
86 CHEVY LB 2WD 77,000 ORIGINAL MILES
86 RX7 "SOLD"
88 RX7 "SOLD"
88 SUPRA "SCRAPPED" DIVORCE SUCKS
2003 HONDA CBR 600 F4I "SOLD" DIVORCE SUCKS
bulkin'up73chevy is offline   Reply With Quote
Old 09-05-2006, 05:28 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: busted ignition
What year truck?
Old 09-05-2006, 06:01 PM   #3
jhow66
jhow66's Avatar
Re: busted ignition
Run wire from hot post on bat. to bat terminal on HEI-to + post on coil if points. On starter solenoid use old screw driver and touch the large post (from bat.) to the small inside post (S) until engine starts. To cut off just remove wire frim bat. hot post. ( not libel for any knots on head while doing the above)
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 09-05-2006, 06:17 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: busted ignition
"What Year truck"
I get so darn frustrated when somebody posts for a fix for a problem and they don't tell you any details. I see in his signiture that he has an 80 super short bed. Maybe that's it. Most ignition switches have a red wire that is hot all the time and another red or pink wire for the ignition feed. These two need to be connected together and then the starter solenoid wire can be touched to these to complete the start then disengaged after the engine is running. I looked in the haynes manual and it shows the normal purple wire for the starter solenoid for auto trannys and a yellow wire for manual trannys, which we also don't know which one he has. If it is a manual there is a clutch interlock which still has to be closed by pushing the clutch in.
The key switch was in the steering column and I'm assuming it's broken out and he can get to these wires. HTH.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-05-2006, 06:34 PM   #5
Longhorn Man
Re: busted ignition
I saw the signiture, but was wondering if this was posted in the wrong forum, or if he had a 67 - 72 work truck not mentioned.
Just jumping to the HEI will let the engine run, but it won't charge, and you'll have no turn signals or anything else from the Acc circuits.
